As you know, SMS is the basic function of a mobile phone, and we are used to send text messages on many occasions. Want to copy android sms to pc avoid losing them accidently? Puzzled in how to transfer text messages from android to pc? Well, now I'll guide you how to copy text messages from android phone to computer with Coolmuster Android Assistant.
It's very easy, we just need 2 steps to finish the work:
Step 1:Connect Android Phone to pc
The first thing you need to do is to download and install the Android contacts manager on your pc and launch it. The next is connect your Android phone to pc via usb cable. Your device will appear on the screen. The manager would recognise your android device automatically.
Notice: If this is the first time you connect android phone to the problem on computer, you should enable USB debugging first, and install a USB driver on your computer, then the app would detect your android phone automatically.
Step 2:Select sms and Start Export
You can find many icon on the left, find "Contacts" and click it, all then go to "SMS", then all sms on your android phone will be listed on the right. Then select and check you want to transfer, at last click "Export" to start the work.
That's all, very easy, right?
A wide range of Android brands are supported by this Android managing tool, including HTC, Samsung, Motorola, Sony, ZTE, LG, HUAWEI, Dell and many more.
