How to Unlock Samsung Galaxy Phone, Remove Samsung Lock Screen?
Tmzmo623
How to Unlock Samsung Galaxy J7 without Losing Data?
How to Remove Lock Screen PIN on Samsung Galaxy Note 5?
How to Disable Lock Screen Password on Samsung Galaxy S7?
How to Turn Off Screen Lock Pattern on Samsung Galaxy Tab 10.1?
Are you also looking for a simple way of how to unlock Samsung Galaxy phone without passcode/fingerprint, or forget the PIN/pattern? Samsung Lock Screen Removal can help you.
Samsung Lock Screen Removal, which is an all-in-one data recovery tool for almost all Samsung Galaxy devices. With the help of this program, you can not only restore the lost and deleted content like photos, videos, contacts, call logs, messages, WhatsApp chats and more from your Samsung Galaxy device including Samsung Galaxy S/Note/A/J/ON/Tab, but also one click to fix a bricked Samsung and unlock your Samsung Galaxy S/Note/Tab without losing data. So, you can one click to bypass the lock screen on Samsung Galaxy phone & Tablet by using this tool.
Step 1. Launch Samsung Lock Screen Removal and select the mode
Step 2. Connect your Galaxy phone and enter the download mode on your device
Step 3. Download recovery package and remove the lock screen
dgrhyh
Here, I strongly recommend a software - Android Lock Screen Removal that focuses on the mobile phone industry
AmandaColey
As you will be upset by the data loss caused by factory reset, you need an alternative that strongly protects your files and quickly unlock your Samsung Galaxy.
Now, the FORecovery Android Lock Screen Removal toolkit can efficiently remove the pattern/password lock screen without data losing. The most important thing is that you won’t lose any data of your phone when unlocking the screen.
Alisawangly
Free download Eelphone Samsung Unlock, when you forgot or didn't know the password. The tool will put your Samsung into Download Mode, then you can unlock Samsung, just within several clicks, you have unlocked Samsung screen lock.
MagloireHunt
Also here is a video about unlocking Samsung Galaxy phone without password, which can help to remove the Samsung lock screen. And no data loss!
