If Scanpst.exe fails to fix PST errors, use an Outlook PST repair tool.
shivgupta
Scanpts.exe is really an effective and secure application of mS Outlook that can help you to fix PST error issues within seconds. If you are unable to solve PST corruption issues with Scanpst.exe, then you can use a third party Outlook PST repair software. The software can not only repair corrupt PST file, but also recover all lost or inaccessible data from corrupted PST file without making any change in original items. This utility supports almost all versions of MS Outlook, including Outlook 2016, 2013, 2010, 2007, 2003, 2002, 2000, 98 and 97. For more information, visit: http://www.pstoutlookrepair.com/
barsewatson
With the help of Outlook PST Repair tool you can easily resolve your all Outlook related issues. It's much capable of recovering all PST mailbox data like emails, contacts, calendar, tasks and etc. This software is also well supports all versions of MS Outlook and Windows platform. Get information, visit from: http://www.fixpstfile.net
Vernon Philander
Superb Outlook PST Recovery software is much helpful to repair corrupt PST files. This is a total solution which consists of an advanced algorithm which ensures the complete and instant recovery of Outlook data. Also, it is also useful in repairing all types of corrupt or damaged PST files very quickly. This also works to repair the password protected PST files.With full version of outlook pst repair software provided by us, you can save all the recovered data from corrupt PST files in either outlook or outlook express file formats. Use Free Trial version to see preview of Recoverable Emails Items.
Phillip Roberts
For repairing PST files, The only solution is to repair corrupt PST file data as possible and create a new file with that data, you can use a file repair tool like 'scanpst.exe' (This work only if the PST file corruption is minor)
If that fails, then you have to use a third party PST Repair Tool. There are various software of such kind available in the market, you can do a web search and look into those.
Robinsan Shaw
The Inbox Repair (ScanPST.exe) tool is an inbuilt utility provided by Microsoft, which can easily repair minor corruptions in PST files. But when Outlook PST files are severely corrupted or damaged, one should go have go for a third party tool. While I was searching in Google, I came across an article which explains a free Outlook PST Repair tool.
For more information refer the link given: https://gallery.technet.microsoft.com/office/Free-PST-Repair-Tool-to-530935ab
If you are searching any Outlook PST Password Recovery software you will get lots of software, But I Suggest you to use DataVare Outlook PST Password recovery software. With this Software you can remove your outlook password in a few minutes. You do not need to do anything more here, after downloading the software, first you have to select the lock file, then click on the recovery option. So it’s a simple software to recover your Outlook file password.
alex786
One more solution I would suggest here named Shoviv Outlook PST Repair tool which provides a simple and secure way to repair corrupted PST files and restore permanently deleted items from PST files. It also provides options to export PST into Office 365, Live Exchange server, New PST, EML, and MSG format.
Read More: PST Repair tool to Recover and Fix Corrupted Outlook PST Files
996
For Migrating from OST to PST you can use ATS OST to PST Converter software which is designed with the rich algorithm for the conversion. It is able to perform the entire task with 100% efficiency and don’t worried about size limitations because you can export any size file without facing any difficulty and your data is always the same as before. It always ready to convert OST data into several file formats like PST, EML, MSG, HTML, EMLX, vCal, Office365, Live Exchange Server, MBOX and vCard without creating any difficulty. Before finishing the conversion it shows the preview of recovered mailbox.
Read More: Free OST to PST Converter Software to Recover Corrupted OST
Gioisoiap
If you are searching any Outlook PST Password Recovery software you will get lots of software, But I Suggest you to use Eelphone Outlook PST Password recovery software. With this Software you can remove your outlook password in a few minutes. You do not need to do anything more here, after downloading the software, first you have to select the lock file, then click on the recovery option. So it’s a simple software to recover your Outlook file password.
It worked, thanks a lot~
