InQuit OST to PST Converter
InQuit OST to PST Converter have features like:
Convert multiple mailboxes:
The user can convert single mailbox items as well as multiple mailboxes items which include like inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time).
Selective files: It eligible to select the particular folder which you want to convert and you can deselect the checkbox if you are not interested to convert it. It can save your precious time.
Supporting platforms: This tool support all the essential platform to make the conversion process simple and smooth.
Support multiple formats: It allows the users to save their final result into different-different useful formats like PST, EML, EMLX, vCard, vCal, MSG, and MBOX.
I recommend to use OST to PST Software to recover and convert Offline OST files into Outlook PST file format with 100% data accuracy. The tool is available with free demo edition to give complete satisfaction for all users before purchase the license version. It is a standalone application that doesn’t required any third party application to complete the process so go with this software to solve out OST to PST migration related issues.
More info visit here:- https://www.datavare.com/software/ost-to-pst-converter-expert.html
ruchika
I would like to suggest you Ignissta OST to PST Converter software to convert OST file to PST file. It can also repair and recover damage OST File to Outlook PST file.
# No file size limitations, Convert unlimited ost file to pst file
# Provide 100% safe and secure conversion results with 100% data accuracy
# Supported all MS Outlook Versions such as 2019, 2016, 2013, 2010 and 2007
# Capable to convert multiple file format such as PST, Vcard, Office 365, EML, MSG and EML
Download Trail version and convert ost file to pst file https://www.ignissta.com/ost-to-pst-converter/
1. Browse and Select OST file ---------> 2. Preview Mails Items ----------> 3. Export to PST file
Lots of vendors are available in the market for recovering data from OST file but I suggest you SysOZ OST to PST Converter software that is the great application which provides satisfying result after recovery process. The process is very easy and understandable. You can convert your files into formats like PST, EML, EMLX, MBOX, MSG, vCal, vCard, Office365 and Live exchange server file formats. This tool allows saving OST data into above file formats.
jamesband
You can try the OST to PST Converter app which is the great solution for transferring inaccessible OST files to PST file without having any trouble. You can use this tool to get error less and accurate results. It consist of different advance features which makes your migration process smooth and secure to perform. You can operate this software on all updated version of MS Outlook and Windows. To know more kindly visit here:- https://www.softakensoftware.com/ost-to-pst-converter.html
Get a free demo version of ATS OST to PST Conversion software which allows you access 30 emails in each and every folder free of cost. With the help of this program, you can see the preview of recovered mailbox before the actual conversion process. Through the help of this program, you can convert single as well as multiple files at a one time without losing data originality. After the recovery process, you can save your data into several file formats such as PST, EML, MSG, HTML, EMLX, vCal, MBOX and vCard. This is the grate in work and it provides 100% accurate result.
