Is data recovery possible on an erased iPhone 5s?
When an iPhone 5s gets lost/stolen. And the data gets erased/reset by the new owner, will he be able to run any data recovery techniques to recover some of the data/photos/other content?
Askiyytr
Coolmuster iPhone Data Recovery is a fast and safe solution for your lost data recovery from iPhone . This iPhone Recovery provides easy and quick data recovery solutions to recover lost files from iPhone .You can recover documents,songs,messages,photos,notes,calendar,bookmarks,video , e-books etc.
Pleake
  1. Tap Settings > iCloud. Scroll down and tap Sign Out. In iOS 7 or earlier, tap Delete Account.
  2. Tap Sign Out again, then tap Delete from My iPhone and enter your password.
  3. Go back to Settings and tap General > Reset > Erase All Content and Settings. If you turned on Find My iPhone, you might need to enter your Apple ID and password.
  4. If asked for your device passcode or Restrictions passcode, enter it. Then tap Erase [device].
Renee
You can check if you have a recent backup in iTunes or iCloud or you may make use of a data recovery tool to retrieve you lost data.
Alenliu
If you just press [delete] or [format] button to erase your iPhone, pro data recovery tool can easily recover it. You need to use iPhone Data Eraser program to erase your iPhone without recovery.
kaoler1
If you sync the phone with iTunes before, you can go to iTunes>Preferences>Devices, you will see the backup list, choose the recent backup that you are certain contains the data that you need to restore. you also can access iCloud backup to recover deleted iPhone data, the last way is using iPhone data recovery software, you can use it to scan your phone and get data back, if the data are not overwritten, you can get all of them back.
alanmore
Yes, it is possible to get back the deleted data from iPhone 5s. You just need the best iPhone Data recovery software. This software can scan your iPhone deeply to find the deleted data for you. You can recover deleted text messages, photos, videos, contacts, call history, notes, reminders, calendars, voice memos, voicemail, safari bookmarks and other deleted data from your iPhone 5s. If you have backup file for you iPhone, you can also scan your backup file and extract data from the file. Learn how to recover deleted iMessages from iPhone here. You can also follow this guide to recover other data. The operation is the same and you just need to select different data to recover.
brant
If your iPhone is lost or stolen, you can use your previous iCloud or iTunes backup files to restore files and setting to your new iPhone. You can recover your Kik history, WhatsApp messages, notes, photos, iMessages, contacts, videos and other iPhone data which have backed up before. If you still hold your iPhone and just want to get back your iPhone contents without backup files, you can apply an iOS data recovery software that supports you to extract data from your iPhone device.
Yes, of course. You can get your deleted/lost data back with Jihosoft iPhone Data Recovery software due to various reasons, including the data loss caused by erasing iPhone.
This software can recover deleted/lost contacts, text messages, photos, videos, notes, WhatsApp, Viber, etc. from iPhone, iPad or iPod Touch directly.
Hope it will be helpful for you.
korence
It is not possible to erase data on devices. The tool that I have used to recover data from iPhone X is named iPhone Data Recovery. It is for all iOS users to recover lost or deleted photos, messages, notes, contacts, whatsapp messages, video, music, etc from iPhone, iPad, iPod, iTunes/iCloud backup files in 3 steps. First to choose data recovery mode, second to scan and preview data, third to recover all data in seconds. You can learn its detail functions on Tuneskit software. Hope this tip is useful to you.
Mans1950
To recover data from an erased iPhone, you use iPhone Data Recovery. If you have backed up the iPhone regularly, you can use this program to recover erased data from iTunes/iCloud backup. If not, you can also use the tool to recover lost data from iOS devices like iPhone, iPad, iPod in 3 steps.
anthony34
if you have made backup of your data on icloud then it's possible to recover your data from erased or dead iphone, otherwise, there are some softwares available but don't know if they work perfectly or not.
Salinamati
Of course, iTunes and iCloud backup files still the freeway to get back erased iPhone data , just turn to your backup files. But if no have backup files, Eelphone iPhone Data Recovery tool to scan iPhone deeply, erased iPhone data may be stored still in iPhone inner storage, try this tool to recover erased iPhone data.
Related detailed guide: Recover deleted photos from iPhone
