Merge Outlook PST data utility
jaky
Is possibile to merge contact information from different version of the same contact ? I have lost information for some contacts, information that two weeks were in mail contacts.
I am very much amazed to see the security and accuracy this product gives and very happy using Outlook PST Merge Software. It was helpful and I really liked it very much. I will definitely suggest this software to many of my business partners and Outlook users.
  1. It does not only merge PST files but also remove duplicate items from merged PST files.
  2. Users can use this utility to merge Outlook contacts only across PST files.
  3. Users can include or exclude deleted items while merging PST files.
ruchika
Must Download and Install Ignissta PST Splitter and Merger software to merge multiple pst file to single pst file. This Utility toll provide best solution to merge pst file.
  1. No File size limitations, merge unlimited pst files
  2. you can merge multiple pst file and create new pst file
  3. you can merge pst files with existing pst file
  4. No outlook installation required while merge pst file
  5. Remove duplicate emails while merge multiple pst file with single pst file
Download and Install Demo version and merge pst file with first 50 emails items https://www.ignissta.com/pst-splitter-merger/
davies
The Merge PST files are a great solution to your problem. You can Softaken merge your entire files of PST with the help of this tool. This software is easy to operate and very safe for merging small and big files. The Merge tool can never be lost your data and never compromise with the originality of the data.
