MS-Outlook OST to PST Conversion
Generally, Microsoft outlook creates its database in 2 types of files called OST (Offline Storage Table) & PST (Personal Storage Table) files, OST files allows us to work offline & later once we made connection with Exchange Server, we can synchronize our offline OST files with MS-Outlook , But it’s not easy because of some hardware & software problem these OST files get corrupted & will not be synchronized with MS-Outlook. So for this, we need to convert our OST files into PST files.
There are many ways to convert OST to PST but the most common method is by using a converting tool.
InQuit is the recommended tool & most reliable tool to do this, Following are the features of this tool:-
  • It can repair the OST file & can export into PST file without making any changes in the previous OST file.
  • Can convert multiple OST files into PST file without losing any file or data.
  • By this tool, we can easily recover damaged OST files & can save recovered OST files in different formats like PST, EML, MBOX, MSG, EMLX, vCal & vCard as well without losing any data.
  • Can restore lost & permanently deleted items & restore them back in same file format.
Read More info: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com/
alex786
Outlook OST to PST Converter tool from Shoviv is providing a reliable and fast solution to convert OST files into PST, EML, and MSG format. With the help of this tool, you can also migrate your OST data into Office 365 and Live Exchange server. It works smoothly with corrupted and non-corrupted OST files as well.
Read More: www.ostmailrecovery.com/
I would like to suggest another OST to PST Converter application for Mac that can migrate OST file into pst file format. It can easy to transfers all OST email data, such as emails in the Inbox, Contacts, Calendars, Tasks, Notes, etc. This software saves and recovers into a new file of PST file format on the Mac Operating System.
PDS OST to PST Converter is well developed tool that easily compatible with Microsoft Outlook versions from 97 to 2019. This software supports smooth conversion of OST to PST, Office 365, EML, MSG, HTML, PDF and MBOX with all OST emails, contact, calendar, task, notes, journals and appointments etc. This is reliable tool and provides you free demo version for understanding the functionality of software. Under demo edition you are able to convert 20 emails from each folder.
Download Software-
If you are looking for an OST to PST Converter then, don’t waste your time on using some online tool because they have limited features and also you will not get your desired result. On the contrary OST recovery tool for desktop-like ATS OST files to PST files converter provide your better result and make all the conversion process simple and sophisticated, it support formats like EMLX, vCard, vCal, MSG, and MBOX, HTML.
Here available one of the perfect and excellent features based SysOZ OST to PST Converter Software which helps you to repair corrupt OST file data and able to save the converted OST emails data into PST, MSG, EML, EMLX, MBOX, vCard, vCal, Office 365 and Live Exchange Server account with complete mailbox items and Meta properties etc.
davies
I would like to refer OST to PST converter application that has the ability to delivers 100% accurate result. To use Outlook OST file data in any PST format user need to migrate OST file to PST format. To migrate OST to PST format reliable approach is the use of professional OST to PST migrator. I found a blog that explains the OST to PST file. You read that blog from this link: 3 Important Points to Convert OST to PST in MS Outlook
ruchika
Ignissta OST to PST Converter software is best Utility software which gives safe and secure conversion results without any data loss.
Important Features for OST Converter
  1. No File Size limitations, convert large ost to pst files
  2. Capable to convert multiple file format like PST, Office 365, Vcard, EML, MSG and MBOX
  3. Split Option is there to convert large ost file to small size of pst file
  4. Supported all MS Outlook Versions like 2019, 2016, 2013, 2010 and 2007
Easy and Simple Process for OST to PST Conversion
Browse OST file ------------>
Preview Email Items ----------------> Export to PST files
tomhayden
Here I am sharing my knowledge because before a number of days I am suffering the same distress but that time I tried OST to PST Exporter Software and resolve to my query in very short period of time. Now, you can effortlessly move OST to Outlook PST including all data.
johnsheno
Here is the fastest method of making the conversion of OST file to PST name as the OST to PST Converter Software. The software interface is user-friendly. You can take a free trial with the demo version of this software which also allows users to convert the first some items per folder. it also has the ability to migrate OST database into several interesting file formats such as MSG, EML, EMLX, HTML, and MBOX. You can watch the preview of the recovered mailbox before finishing the conversion.
