InQuit NSF to PST Converter is a famous name in the data conversion market, it is equipped with a very rich algorithm and the best technology that make it super smart. This tool is known for its intelligent features and 100% accuracy. This is really helpful for completing the conversion task. With the assistance of this program, users can easily and smoothly convert their Lotus Notes data into Outlook PST data file. At one time users can convert email, task, attachment, draft, notes, inbox, contact, calendar (To, Cc, From, Date, Time, Subject, Object and Bcc) into new workable PST file without any hassle.
Its smart features are listed below:-
• Easily extract NSF data into PST data file with the aid of this program.
• It is compatible to show the preview of recovered mailbox before the conversion of Lotus Notes to PST Outlook.
• Export password protected and encrypted NSF file in a safe manner.
• Recover lost and permanently deleted data through the assistance of this program.
• The users directly export their data into cloud-based application Office365 & live Exchange Server that is an additional feature of this tool.
• Save final result into several interesting file formats such as PST, EML, EMLX, MBOX, HTML, vCal, CSV, vCard, and MSG file format.
• It backing MS Outlook version up to 2019.
• Support Lotus Notes version 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5, 6.0 and, 5.0.
• MS Outlook installation is not mandatory for the conversion.
Conclusion
In the last, I suggest you download this tool quickly that has the best features to solve your problems related to NSF to Outlook PST Conversion. You can download its free demo version that allows you to convert 30 emails per folder free of cost that is the best facility to judge software before purchase it.
Read More Info: https://www.inquitsoftware.com/en/nsf-to-pst-converter.html
Worried about Lotus Notes corruptions then choose eSoftTools NSF to PST Converter Software. It can work well with any version of Microsoft Windows OS. It can convert NSF files into various file formats such as PST, EML, EMLX, HTML, MSG, vCard and many more. This can restore all the information without any modification in the index of the files and folders. A free trial version is present to try.
1041
Explore more:
margkerberg
For the conversion of Lotus Notes to Outlook, I suggest you ATS NSF to PST Converter application that shows the preview of recovered mailbox along with email, inbox, outbox, contacts, permanently deleted items, drafts emails, calendars, sent items, notes and Meta properties(to, cc, bcc, subject, date and time). Using this application you can migrate single as well as multiple files in a little moment. It does not create any difficulty in the conversion of NSF to PST. It support OS Windows version like 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). The free demo version of this program allows you to convert 25 emails into PST, EMLX, MSG, HTML, CSV, MBOX, vCard, and EML file format without any penny
Download freeware Lotus Notes Converter tool visit: Convert Lotus Notes to Outlook PST file
NSF to PST Converter software which can easily export IBM Lotus Notes all emails, items, folders, into Outlook PST Format. It provide facility with this tool that converts NSF file into PST file Format because both of these format are very easily to access and reliable for safety. Download this application to effortlessly transfer NSF to Outlook PST file with every single data available existing with NSF mailbox.
devin
Try one of the best Tool to Convert NSF to PST application that is the expert in the data conversion field. By using it you can easily export single as well as multiple NSF mailboxes without any difficulty. The users can export their password protected and encrypted data in a secure way. It backing Lotus Notes Version 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0. The users can directly export their data into Office 365 & live Exchange Server.
More Info :- Tool to Convert NSF to PST
For better performance and best conversion process, Use the popular software Shoviv Lotus Notes to Outlook converter. It converts multiple Lotus Notes NSF files to PST Outlook in a few clicks. It provides more features like It export NSF files into EML, MSG, and HTML. Shoviv provides the guarantee for better safety and migrates data without any loss. It supports all versions of Lotus Notes, Outlook, and Windows OS. Download its free trial version and migrate the first 25 items per folder.
More details, visit:-
Convert NSF to PST
One can try a tool like eSoftTools NSF to PST converter software to migrate information in Microsoft Outlook platform without any data loss. One can restore data into numerous file types which include options such as PST, EML, EMLX, HTML, vCard, MSG, etc. one does not need any technical knowledge to operate this tool efficiently. Many file folders can be selected for exportation in a row. Each email can be re-established with all its components which may comprise of bcc, cc, time, date, attachments, etc. A demo version is also offered to each user for conversion and restoration of damaged file for free. MS Outlook installation is not needed.
Explore more about free NSF to PST converter here
You can try the SysInfoTools NSF to PST Converter Tool.
With this smart utility you can easily perform the conversion and it offers various other features such as:
  • Safely converts NSF to PST file format without causing any alteration in the data
  • Export Lotus Notes email messages, contacts, calendar, etc. to Outlook client
  • Single and multiple NSF files are supported by this Notes Migration tool
  • Auto-search option available to search NSF database files in your system
  • Smart preview feature to check the mailbox content of NSF database
  • Remove Encryption from the Lotus Notes emails
  • Use Date Range feature to exclude undesired Lotus Notes files and content
  • Exclude All folder from the new output PST file
  • Saving DocLink and Internet Header options are now available
  • Allow users to define Email Address Translation: Set SMTP Manually and/or Add CSV File
  • Enable Custom Folder(s) Mapping option for new output PST file
  • Supports large-sized NSF database with ease, i.e. up to 50 GB
  • User-interface is now more robust and interactive with new saving function
You can try the free version of this tool to experience the working of the software.
davies
I would like to suggest you can also try NSF to PST Converter application. This utility allows the user to migrate NSF file into PST etc. It is a useful software that lets you transfer NSF to PST file formats. By using this third party tool you can easily import all Lotus Notes NSF data into PST file formats without any data losing. It supports all MS Outlook versions.
jackbryan
When you are unable to access your important database that is stored in the NSF file, So NSF file to PST file format of Microsoft Outlook can be the best option for you. You can try this eSoftTools NSF to PST Converter Software to simply move the NSF file inner elements such as emails, contacts, chats, tasks, notes, etc to an accessible PST file format. It is also capable to migrate your NSF file items to some unique file formats such as- PST, EML, EMLX, MSG, HTML, vCard, CSV, MBOX, and ICS. Before purchasing it your try a free demo version of this software which is available on the given link.
Get More Info:- https://www.esofttools.com/nsf-to-pst-converter.html
