camilia
If you need to Export OST files into MBOX Thunderbird format, then you can Try KDETools for OST to MBOX Converter software that provides multiples features facilities. by Using its application you can the large-sized OST files can be converted into MBOX format with safe all Email properties or mailbox attachmnets. The software provides secure and complete risk-free conversion of data. This software is affordable and beneficial for those users who want to convert OST data files to another file format. It supports all versions of MS Outlook and Mac OS.
Download , install and run OST to MBOX Converter.
Click on the "Open" button to select OST file.
Select the "Export" button from the menu.
Select "Destination Path".
Select MBOX as an export option.
[Optional] Select the checkbox "Message Filtering" to filter messages as per the date range.
More Info- OST to MBOX Converter
