OST to PST Converter and Recovery Tool
ralphmiller
OST to PST Converter tool is an email converter and recovery utility for Outlook offline data. The primary function of this software is to repair corrupt OST file without losing any data and then save recovered emails and other data to PST and many other formats.
  1. Convert OST file to PST, MSG, MBOX, EML, EMLX, vCard and vCal file formats
  2. Option to directly export mailboxes from ost file to office 365 & Exchange Server
  3. Recover every folder including Inbox, Outbox, Sent Items, Deleted Items, Drafts, Contacts, and Calendar etc.
  4. No limit of OST file size with this tool.
  5. Supports Outlook 2016, 2013, 2010 and more versions.
Download OST Converter- vmail-ost-to-pst-converter.en.softonic.com
try this OST to PST Conversion tool which easily migrate your ost file to pst file & other format, in case of accidentally Server down, virus attack, connectivity loose its start creating .ost file in the place of .pst.
ATS OST to PST Conversion tool is workable software to repair OST file from corruption. This expert application serves great facilities to recover OST database like email, contact, inbox, sent an item, delete an item, draft, calendar, notes, contact, task, attachment, outbox (to, cc, bcc, subject, date and time) with 100 % guarantee. This application work with all the version of MS Outlook version up to 2016. This application shows the preview of recovered mailbox items before the conversion process. Our engineers 24 x 7 hour available to solve all the query related to OST recovery utility.
Get more details: ATS OST to PST Converter
The OST to PST Converter tool for Mac is the accurate and reliable option for the Mac users by which you can simply get the OST files converted into PST format. The resultant PST files can be imported to any version of MS Outlook without any problem. This software can run on all updated versions of Mac OS without facing any problem for the conversion.
PDS OST to PST Converter is error-free solution that securely converts OST to PST with all its folders and sub-folders. It converts OST to Office 365, MSG, EML, HTML, PDF and MBOX including all email properties with attachments. Not only convert, this software gives another advantage to recover damaged OST file with every single elements.
Your OST file has corrupted in two ways hardware based and software based. Hardware-based means data storage device failure lost internet connectivity sudden power failure etc. To solve out this problem you can try Free OST to PST Converter application. Before the actual conversion task you can save your data into new accessible PST file format. Apart from it support EML, EMLX, MSG, vCal, vCard, and MBOX file formats.
Read more: https://www.inquitsoftware.com/en/ost-to-pst-converter.html
If you are looking for the OST to PST converter and recovery tool, use eSoftTools OST to PST converter tool. This program is the multi-functioning tool, it recovers all damaged and corrupted OST files and folder including E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent items, Calendar, Tasks, Notes, Journal folders, and this tool converts the OST file into many different formats like HTML, PST Outlook, CSV, EML, MSG, Office 365, MBOX and vCard to access the information to the user as per the requirement. This tool supports all version of MS Outlook and a smart preview is shown to the user before converting the file into other formats.
Know more:- https://www.esofttools.com/ost-to-pst-converter.html
1337
eSoftTools OST to PST Tool permits users to export selective items from the Offline OST file to many different file formats such as PST, EML, EMLX, MSG, HTML, vCard, VCF, and many other file formats with maintaining the previous structure of the OST Database. This OST to PST Converter has the power to repair all types of damage and corruption issue from the OST file and give the facility to recover and convert the database like emails, chats, tasks, notes, and more to Outlook PST very easily.
Get More Info: OST to PST Recovery
jamesband
If you are having trouble in the conversion of OST file to PST format. You can use OST to PST Converter that will work without any issues for you. The tool assures you no loss of any data file and no compromise with file quality.
If you are facing any problem in the migration of OST file to PST format on the Macintosh PC. You can use OST to PST Converter for Mac that will help you to perform this conversion without any error on your system. The utility assures that not to damage any data files and no alteration with quality. To try this tool you can visit here:- https://www.mailvita.com/ost-to-pst-converter-for-mac/
Shoviv OST to PST converter is the feasible way to convert OST data to PST. The tool Shoviv OST to PST converter is proficiently capable to convert the multiple OST data to Outlook PST and also export OST data into Live Exchange Server, Office 365, EML, MSG, and HTML formats. It provides secure and error-free conversion and proficiently recovers permanently deleted and corrupted OST items. It supports all versions of Outlook and Windows OS. Download its demo to convert the first 25 items per folder.
More details, visit:-
Convert OST to PST
Instantly recover corrupted OST file and folders just in a couple of minutes by using best OST recovery tool available by eSoftTools. This program helps to recover all OST file and folders information including E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent Items, Calendar, Tasks, Notes, Journal folders. It efficiently converts OST file into various types of format like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook to access information to the user. Before the conversion and recovery of the smart preview is shown to the user to check and confirm the formats of conversion and file structure. This program smoothly functions with all file versions such: 2000, 2003, 2007, 2010, 2013, 2016, 2019. A TRIAL PACK is available easily up to 25 emails can be converted into all formats.
Get more info:- OST to PST Converter
SysOZ OST to PST provide best method to converter and recovery tool to fix .ost file data into .pst file data with complete emails attachments. OST to PST software product are almost the same. All product support MS Outlook version, Window version. All the users are compatible to convert their data into several file formats such as PST, EML, MSG, EMLX, vCal, vCard, MBOX. With the assistance of this program, you can migrate single as well as multiple files at a one time.
Any e-mail enthusiast and IT tech-geeks would love using this OST to PST Converter made by guys from CoolUtils. The software is very helpful and saves me a lot of hassle at work. Definitely a must-try. One of the best software I found on the market. Easy to recover your all important items like emails, attachments, contacts etc.
Read more here - www.coolutils.com/OSTtoPSTConverter
jackbryan
Instantly recover and convert OST file into PST Outlook through eSoftTools OST to PST Converter Tool, this converter tool is the best option to convert the corrupted OST file into multiple formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. It does not need installation of MS Outlook for converting OST file and smoothly functions with all file version of MS Outlook such: 2000, 2003, 2007, 2010, 2013, 2016, 2019. A smart preview is shown to the user to check and confirm the conversion format.
Salinamati
In 2019, it's to OST to PST Converter, what's more, Outlook Repair tool and Outlook converter tool can combine into one tool.
1. Import corrupted or deleted OST/PST files on computer automatically or manully. Of course, normal OST/PST files can be also moved into the conerter.
2. Select the OST/PST file
3. Define the output format of selected files, we can select PST as the output format.
Convert and recover OST/PST at the same time, and it's easy.
ruchika
I would like to suggest you Ignissta OST to PST Converter software to convert OST file to PST file. It can also repair and recover damage OST File to Outlook PST file.
# No file size limitations, Convert unlimited ost file to pst file
# Provide 100% safe and secure conversion results with 100% data accuracy
# Supported all MS Outlook Versions such as 2019, 2016, 2013, 2010 and 2007
# Capable to convert multiple file format such as PST, Vcard, Office 365, EML, MSG and EML
Download Trail version and convert ost file to pst file https://www.ignissta.com/ost-to-pst-converter/
1. Browse and Select OST file ---------> 2. Preview Mails Items ----------> 3. Export to PST file
For the conversion process the SysOZ OST to PST Conversion application always ready. Using this tool all the user easily recover their data and convert into a new accessible file format that is PST. It is very simple to use for everyone even a novice user can easily operate it for converting the data from OST file to PST file. After the conversion process, the user collects their final result into several file formats such as PST, EML, EMLX, vCal, vCard, MSG, and MBOX.
piteralexie
There are multiple conversion tools are available in the online market for converting the OST file into PST file format. But here I am providing you the best utility name as eSoftTools OST to PST Converter Software. You can try this software to convert OST file into PST file format without any data lose.
Some important features of this OST to PST tool:-
  • Multiple file Option to convert the OST File like:- PST, EML, EMLX, MSG, and HTML.
  • Instantly repairs inaccessible or Corrupt OST File
  • Quick & Fast way to make the OST file Conversion
  • Offers a Split facility to make PST file small in size
  • Also, it provides a demo version facility for testing this software, which is capable to recover and export 50 items from every folder of OST file.
For More Information, Visit Here:- https://www.esofttools.com/ost-to-pst-converter.html
