OST to PST Converter- Freeware
ralphmiller
OST to PST Converter is freeware tool which will convert Exchange OST file to PST file to access your data in MS Outlook. This software is able to convert OST file to PST, EML, MSG, MBOX, EML, EMLX, vCard & vCal formats in just a couple of clicks. Using OST to PST Converter you can also restore mailboxes from inaccessible OST file from Outlook. OST to PST Freeware is the best solution to resolve the errors with OST file caused by Exchange Server downtime or crashes and accidental account deletion. After OST to PST Conversion all your emails, contacts, tasks, notes, journals, etc can be opened in Outlook. The software helps you in recovering from the loss of Outlook data stored in Offline data OST file.
Click here for more- OST to PST
margkerberg
Download freeware OST to PST Converter tool to convert offline OST file to PST file . OST to PST converter for conversion OST as PST, office 365 and Live Exchange Server. This tool is include Batch Converter module for bulk or single file repair and recover with convert to PST at a time. OST to PST Software helps users to recovery of selective items from offline OST file and restore OST files into multiple formats such as PST, EML, EMLX, MBOX, vCal, vCard, and HTML.
Advanced Key Features of OST to PST Converter Software
  • Safe and securely recover OST file data from corrupt OST file.
  • Safely restore OST file to office 365, Live Exchange Server and Outlook PST file.
  • Save recover OST file into PST, MSG, EML, EMLX, MBOX, vCal, vCard and HTML file formats.
  • Convert single selected mails item into PST file.
  • Recover selective single and multiple emails with attachments and properties.
  • Convert single or multiple OST file to Outlook PST with other file format at a time.
  • Supports all MS Outlook file versions up to 2016 and windows versions up to 10 (32 and 64 Bit).
  • Provides complete preview recover OST Emails, contacts, calendars, task, notes and appointments.
  • Download freeware OST to PST Converter tool to save 30 mailbox each folder and each file formats.
More info visit: OST to PST Converter tool freeware
Download OST to PST Converter is a well-designed software program that conducts OST file conversion of all the emails with an attempt to save your time. With this version users may easily know the features and compatibility of this software. You can check the compatibility and efficiency of this software.
alex786
Try another one named Shoviv OST to PST Converter software which works with corrupted and non-corrupted OST files and then exports into PST, EML, Office 365, Live Exchange, and MSG. This tool also saves OST files into HTML, RTF, Cal, vCal, and vCard format.
Read More: www.shoviv.com/ost-to-pst-converter.html
InQuit OST to PST Converter tool is now in trends for the purpose of Outlook mailbox recovery and it justify with all the need of the users who are facing the problem of OST files corruption issue, it has the capability to create the healthy PST files from damaged OST files and it also convert healthy OST files to PST files format for further use, so while migrating the database from one server to another server without violating the authenticity of these OST files. Some important and interesting features of InQuit Software are:
• It supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016.
• It can smoothly work with all MS Outlook 98, 2000, 2002, 2003, 2007, 2010, 2013, and 2016.
• Cloud-based application Office 365 & Live Exchange Server are the additional features of this tool, which help to save the file on the cloud-based
• The users can divide a large PST file into a smaller one as per their requirement.
Read more: http://www.inquitsoftware.com/en/ost-to-pst-converter.html
I am introducing most trustworthy Vartika OST to PST Converter for better and perfect conversion of OST to PST. OST to PST Converter is designed with high advance algorithm that takes minimum to scan OST file and then convert into suitable formats- PST, EML, MSG, HTML, MBOX, EMLX, vCal, vCard and PDF platform. It is capable to migrate OST to Office 365 and Live Exchange Server.
Read more- Vartika OST to PST Converter - Convert OST file into PST
PDS OST to PST Converter Freeware is capable to recover data from corrupted OST file and then convert into Outlook PST with all components. It gives you multiple formats as such- EML/ MSG/ HTML/ PDF/ MBOX and Office 365. It converts all versions of Outlook OST file up to 2019 (32 and 64 Bit).
More Info- Free to Convert OST to PST by using OST to PST Converter
SysOZ OST to PST Converter is 100% safe and secure email recovery software that can smartly repair and convert the inaccessible OST file data into PST file data with EML, MSG, MBOX , vCal, vCard, EMLX, Office 365 and Live Exchange Server file formats without any harm original data. It helps you to save the converted OST file into new working PST file format.
For this Conversion of Offline OST file to PST file , you need to use the third-party Program and there are many third-parties available so here I also recommend for every Outlook OST user, used the InQuit OST to PST Converter. With this software, you can convert you all Outlook OST file data into PST or other required formats like office 365, Live Exchange, EMLX, HTML, vCal, vCard, MBOX, MSG, and EML etc.
Read more: InQuit OST to PST Converter
If people are trying to Convert exchange OST mailboxes to PST Outlook format, then I recommended you to use SysInspire OST to PST Converter Software which can convert the OST files of mailboxes to PST Files and save it in MS Outlook file. The OST to PST Conversion Software scans all OST File and preview OST emails, contacts, calendars, task, notes, inbox items, outbox items, journals, and appointments. OST Recovery automatic fixes fix all OST File errors and recover OST File to PST Outlook file.
Search on google- SysInspire Free OST to PST Converter
SoftMails OST to PST Converter software is the best application that securely repair and converts corrupted or damaged OST file to Outlook PST. Use this best OST conversion tool to repair damaged OST file and convert all data of OST file including emails, contacts, task, notes, Journals, and appointments into PST, EML, MSG, HTML, EMLX, MBOX, Office 365 and vCard format. This OST to PST Software doesn’t require MS Outlook installation to recover and convert data of OST file. It offers a free demo version which instantly recovers 25 items from each folder of OST file.
Read More: Free OST Recovery Tool & OST to PST Converter Export OST File
If OST file is corrupted and damaged and unable to access the information from OST file and folder including E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent items, Calendar, Tasks, Notes, Journal folders, Recover all damages OST file and folder just on minimum numbers of click by using the eSoftTools OST to PST converter tool. This tool is the best OST to PST converter and recovers file securely without damaging the other existing files, and it also offers the OST to PST converting option and also various formats like HTML, PST Outlook, CSV, EML, MSG, Office 365, MBOX and vCard. It supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019 and installation of MS Outlook is not required to convert file successfully.
Explore more info:- https://www.esofttools.com/ost-to-pst-converter.html
1332
The Mac users go for the OST to PST Migration Tool for Mac for converting the OST files to PST on your Mac systems and this software is also help you in recovering the inaccessible OST data file and save them into PST format. There is no risk or trouble in using this utility as it simple and easy to operate because of its friendly-user interface.
OST to PST Software to convert OST file from Outlook to PST file. This software can recover Inbox, Outbox, Sent Mail, Drafts, Contacts, Calendar, Tasks, Notes etc from corrupt and encrypted OST file and export to formats like PST, EML, MSG, MBOX, HTML, vCard & PDF
If you are searching for the free tool to recover your OST files and folders including E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent items, Calendar, Tasks, Notes, Journal folders. Use eSoftTools OST to PST converter tool to convert the OST files into PST and other formats like Office 365, MBOX, CSV, EML, MSG, and vCard, HTML. It can easily convert single mailbox and multiple mailbox items just on minimum numbers of clicks, this tool supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019. A FREE TRIAL version is available, the user can easily convert up to 25 emails to each format.
Explore more info:- https://www.esofttools.com/ost-recovery/
jamesband
If your aim is to achieve the accurate result from OST to PST conversion them here is genuine software which makes this migration possible. You can use the Softaken OST to PST Converter which is the professional as well as a trustworthy tool to have for this conversion. It transfers the single and multiple OST files into PST and also helps to recover them. To know more visit here:- https://www.softaken.com/ost-to-pst-converter
margkerberg
ATS Microsoft OST recovery tool is exquisite software for repairing your damaged OST files. This application can convert your damage OST file into PST files without any data loss. If your OST files get corrupted you face lots of problems like unable to Enlarge the folder, the set of folders could not be opened and cannot distinctive Outlook items when offline. This tool can help to migrate your OST file data into PST files and other formats like EML, EMLX, vCal, MSG, and MBOX.
Read More: https://www.bulkecommerce.com/store/ats-ost-to-pst-converter-software-159.html
jackbryan
Instantly recover and convert OST into PST file format by using eSoftTools OST to PST Converter Tool, this tool easily convert OST file into 6+ various formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. To maintain other file secure while the conversion, this tool shows the smart preview to the user to check and confirm the format of conversion. It convert OST file with including all folders like E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent items, Calendar, Tasks, Notes, Journal folders. For the conversion of OST file this tool does not require installation of MS Outlook and it smoothly functions with all file version of MS Outlook such: 2000, 2003, 2007, 2010, 2013, 2016, 2019.
Get more info:- Secure OST to PST Converter Software
MailsClick Convert OST file Tool known for its secure Migration performance about OST recovery and conversion OST File to another file, all users can use it to repair damaged and corrupted offline outlook OST file and convert OST File with emails, calendars, task, notes, inbox items, journals, and other users mailbox items. With the help of the best Convert OST file Software let users save the individual items of OST File into several formats like- PST, MSG, EML, EMLX, MBOX, and VCF format without creating any problem and supports all MS Outlook versions included- 2003, 2007, 2010, 2013 and 2016 (32 and 64 Bit)
