OST to PST Converter- Repair, Recover & Convert corrupt OST files
ralphmiller
If you have a corrupt inaccessible OST file and Inbox Repair Tool fails to repair it, then try vMail OST to PST Converter to easily repair major corruption in OST file and recover all mailboxes, contacts, calendar etc. Further, using this tool you can convert OST to PST, MSG, MBOX, EML, EMLX, vCard & vCal formats. vMail OST to PST Software allows capable to directly export recovered OST emails and other data to office 365 & Exchange Server.
Learn More- Free OST to PST Converter Software OST Recovery Tool Outlook 2016
Get another reliable solution with OST to PST Converter software which provides easy options to recover corrupted OST files and Convert OST to PST files. This tool also works to export OST to Office 365, Live Exchange server, EML, and MSG format.
ATS OST to PST Converter is a great utility to recover OST data then migrate them into newly created Outlook PST file format with all the information and documents of OST file. Using this application you can easily import all the data of OST file into PST, EML, MBOX, MSG, EMLX, HTML, vCal, vCard file format. This software easily works with all the version of MS Outlook from 97 to 2016 and entire below version. It has the smart technology to repair orphan OST file and recover permanently deleted database. After completing the recovery process you can save your OST data into Cloud-based application Office365 & live Exchange server.
Read more details: OST to PST Converter
Convert single as well as multiples files by taking the help of InQuit OST to PST Converter Software which is the best application for you if you want to migrate your data into new Outlook format that is PST. It does not make any changes during the conversion and after the conversion, your data is the same as before. This has lots of advanced features that provide better results than your expectations.
Workable and Interesting Features
Support several formats: This utility has lots of saving formats which play a vital role in collecting the final result. The file formats are PST, EML, EMLX, vCard, vCal, MSG, and MBOX.
Auto scan process: The auto scanning process of this tool deeply scan all the errors and vanished them instantly.
Show Preview: Before saving the OST data into PST data file you can see the preview of recovered mailbox.
Migrate selective files: With the aid of this tool, a user can export only that file which they want to migrate as well as you can transfer all over data as per your need.
Splitting Facility: it split large OST file into several small PST file without creating any size limitation problem.
Supporting version: This setup is workable with OS Windows’s version 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). Support MS Outlook version up to 2019.
Read more info OR Download Software: https://www.inquitsoftware.com/en/ost-to-pst-converter.html
The SysOZ OST to PST Converter tool is fastest and impressive software for repairing the corrupted or damaged OST file data and gives you to full power to convert the OST emails into PST Outlook file format with other many export option like as EML, MSG, and HTML entire whole mailbox items such as emails, attachment, journals, attachment, imaged, sent items, deleted items, contacts, calendar and outbox items without harm any original data.
Read more: SysOZ OST to PST Converter - Software Infocard Wiki
devin
OST to PST converter software which provides an easy and safe solution to export your OST files into PST, Office 365, Live exchange, EML and MSG. This OST to PST Converter Software is useful when we are going to export email, messages, contacts, calendars, appointments and other data of Outlook PST file format.
More Info;- http://www.osttopst.adwages.com/
Convert the OST file into any format like Office 365, MBOX, CSV, EML, MSG, and vCard, HTML, PST Outlook. Use eSoftTools OST to PST converter tool, this tool helps to convert OST file without any size limit. It recovers the OST file and folders like E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent items, Calendar, Tasks, Notes, Journal folders only in a couple of minutes. MS Outlook installation is not required to convert the OST file and it supports all file version such: 2000, 2003, 2007, 2010, 2013, 2016, 2019. A smart preview is shown before the conversion of the OST file to make the conversion format confirm to the user.
Explore more info:- https://www.esofttools.com/ost-to-pst-converter.html
