OST to PST Converter Software
InQuit OST to PST converter is the latest version which takes only a few minutes to have a conversion of corrupt OST File into PST File and other formats like as EML, EMLX, MBOX and HTML. With the help of this utility, you get back your corrupt data safely. You can save your OST files into the cloud-based application like Office 365 & Live Exchange Server and you can convert a single mailbox into multiple mailboxes which include emails, inbox, sent-items, deleted-items, drafts, contacts, calendars, notes, attachment. It has the ability to run smoothly on all the version of OS – Windows 95, NT, 98, 2000, ME, XP, Vista, 7, 8, 8.1, 10 (32bit & 64bit). This freeware only use certain parts of the software program which allow converting 30 emails in each folder.
ATS OST to PST Converter is very helpful to convert OST mailbox data into PST, MBOX, MSG, EMLX, HTML, vCal, vCard, Office365 and live Exchange server file formats. This tool allows you to do work on offline mode. Using this OST recovery application users easily access all entire old and permanently data along with email, contact, inbox, sent item, delete item, draft, calendar, notes, contact, task, attachment, outbox. If you apply manual tricks so it is very tricky and technical for non-professional users. It can smoothly work with all the version of Exchange server from 5.0 to 2016.
Read More Info: Outlook ost to pst converter Software
If you use SysOZ OST to PST Converter it takes only few minutes to transfer all your selected folder or files to PST, MSG, EML, EMLX, vCard, MBOX and many other formats. You can easily retrieve your data by using OST Converter tool. It is a latest version which is discover by our expert using the highly rich algorithm to repair damaged OST file which is damage due to many reason. Download the free trial version of this OST to PST Converter software which helps to endow more know how about the application. Free demo version allows you to save 30 emails per folder without the penny.
How to Convert OST file into PST file Live Demo Video
Read more info view Image
ToolsGround OST to PST Converter software which provides an easy and safe solution to export your OST files into PST, EML, MSG, ICS, vCard, HTML, MHTML and MBOX. This OST to PST Converter Software is useful when we are going to export email, messages, contacts, calendars, appointments and other data of Outlook PST file format.
More Info:- https://www.toolsground.com/ost-to-pst-converter/
jackbryan
Get the best recovery of corrupted OST file by eSoftTools OST to PST Converter Tool, it offers the best conversion and recovery just on minimum numbers of clicks. This utility is full with various features of recovery like:-
  • Easily migrate OST to multiple formats like MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook.
  • Also, convert OST to Office 365.
  • Shows smart preview before the conversion.
  • Installation of MS Outlook is not required for converting file.
  • A FREE DEMO pack is available.
  • Split large OST file into single and multiple PST file format.
You can try OST to PST Converter application this tool easily to migrate single file OST file to PST format. You can download OST to PST Converter tool easily and quickly to migrate bulk OST files to PST file format in a very simple and smooth way. This application supports all MS Outlook and Windows OS versions.
