OST to PST Converter to Convert OST file in PST
InQuit OST to PST Converter have features like:
• Splitting a mega file into several small files according to your need.
• Import single as well as multiple OST files into Outlook format.
• Preserve OST Mailbox item like emails, task, calendar, draft, attachment, notes, and inbox.
• Support several saving format such as PST, EML, HTML, EMLX, vCard, vCal, MSG, MBOX.
• Save PST file for future use into the cloud-based application Office365 and Live Exchange Server.
OST to PST Converter is a great designed software that migrate OST data to PST format. By this tool, the users can recover and access inaccessible OST items such as emails, contacts, notes, journals, tasks, calendars, etc. in an effortless manner. The application works effectively with all editions of MS Outlook including Outlook 2003, 2007, 2010, 2013, 2016, 2019, etc.
More info visit here:- https://www.datavare.com/software/ost-to-pst-converter-expert.html
For breaking large OST file into multiple small PST files you can use ATS OST to PST Migration software which gives 100% accurate result. This application export individual as well as more than one OST files into PST and another file formats such as EML, EMLX, MBOX, HTML, MSG, vCal, vCard. This application support MS Exchange Server 5.0, 5.5, 2000, 2003, and above version up to 2016. It gives permit you to work in offline mode. This tool is also eligible to display the preview before the actual conversion process.
Read more: ATS OST to PST Converter Toolkit
Gioisoiap
It's the easiest converter to convert OST to PST, just import OST file to the converter, and then set the output format as PST, esay and effective.
SysOZ OST to PST Converter tool that easily resolves all the problems and convert OST data into healthy PST file along with emails, inbox, sent item, deletes item, attachment, calendar, draft, task, notes (to, cc, bcc, from, object, time and date) with 100 % accuracy. Users can easily import their data into PST, EML, EMLX, Office365, Live exchange server, MBOX, MSG, vCal, vCard file format. The free demo version is also available for recovering 30 emails per folder free of cost.
Read more:
https://download.cnet.com/SysOZ-OST-to-PST-Converter/3000-2369_4-77992952.html
ruchika
Ignissta OST to PST Converter is best utility software which capable to convert ost file to pst file with Ease. This utility software having advance option which provide 100% safe and secure ost to pst conversion results
  • You can convert OST to PST file with unlimited ost file without any file limitations
  • Provide 100% safe and secure conversion results with 100% data accuracy
  • Capable to convert ost file with multiple file format like: PST, Office 365, Vcard, EML, MSG and Mbox
  • Supported all MS Outlook Version 2019, 2016, 2013, 2010 and 2007
Trail Version available for testing download and install without paying any cost and convert ost file to pst file with first 50 email items per folder https://www.ignissta.com/ost-to-pst-converter/
Easy and Simple process for OST to PST conversion
Browse and Select OST file ----------> Preview Mail Items ----------> Export to PST File
piteralexie
Try this eSoftTools OST to PST Converter software to convert the OST file into Outlook PST file format. By using this tool user will get the capability to export all emails, contacts, calendars, tasks, journals, reminders, and other items from a corrupt OST file to a new file format as PST without any alteration.
Numerous advanced features of this tool-
  • Supports to convert selective single as well as multiple OST files at the same time.
  • It has a simple and easy to use graphical interface.
  • Maintains all folder hierarchy and text formatting after making the conversion.
  • Supports all editions of MS Outlook (up to- 2016).
  • Compatible with all Windows O/S versions including- 10, 8.1, 8, and all previous versions.
Get more information about the tool and download it from here: https://www.esofttools.com/ost-to-pst-converter.html
