OST to PST Converter tool- all Window supported
One of the best window support SysOZ OST to PST Converter Software to fix OST file damage problem and helps all users to convert the offline inaccessible OST file into PST, MSG, EML, MBOX, vCard, vCal and EMLX file formats. This OST Converter tool is simply support cloud base emails application export offline .ost file into Office 365 and Live Exchange Server account with complete attachment etc.
*Repair Corrupt / damage OST file data.
*Export the offline OST file into PST, EML, MSG, MBOX, EMLX, vCal, and vCard formats.
*Convert the OST file in Office 365 and Live Exchange Server account.
*Support the all Outlook file versions without facing any problems.
Read more: OST to PST Converter Download
You can try this OST to PST converter software to convert and export OST data in Outlook supported PST file. After conversion process of OST file, just directly import to PST file in any version of Outlook along with complete data. You can export your files from OST format to Outlook PST format file.
Using OST to PST Converter application you can easily convert Outlook OST data into PST data file along with email, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (To, Bcc, Cc, Subject, Object, Date, and Time) without any hassle. It is 100% safe and secure for the conversion task. The users also migrate password protected and encrypted data in a safe manner without losing any information. With the aid of this program, you can see the preview of recovered mailbox along with all the data of OST mailbox without any difficulty. It supports MS Outlook version up to 2019 and Office365 & Live Exchange Server
Read More info:
Microsoft OST to PST Converter Software
If you are looking for best OST to PST converter tool then we suggest you a great program which repair & recovers your damaged ost file data very easily. Apart from its user can also export their offline OST file data into office365 & live exchange server with PST, EML, MSG, MBOX, vCal, vCard, HTML file types. This software recovers your all emails, Contacts, calendar, task with meta properties( To, Cc, Bcc, Date, From, subject and attachments) and users can also export multiple files as well as a single file in just a couple of clicks. It supports MS Outlook all versions 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
Read More Details: https://download.cnet.com/InQuit-OST-to-PST-Converter/3000-2369_4-77972350.html
1044
jamesband
This OST to PST Converter software provides the best solution to Convert your OST file without any intervention. This software safely converts all mail items of Offline folder (OST) file and saves them in new Outlook PST file, along with giving the option to save as EML, MSG, and MBOX formats. You can test the software on any version of MS Windows operating system for any version of MS Outlook and MS Exchange server as it is compatible with the entire range of versions of all of them.
More Info;- OST to PST Converter
For Quick and hassle-free OST to PST conversion, try Shoviv OST to PST converter tool. The tool Shoviv OST to PST converter provides the facilities to recover the deleted and corrupted OST Items and convert into PST Outlook, Office 365 and Live Exchange Server. It also exports data into EML, MSG, HTML formats. Download its free trial version to check the efficiency of the tool and convert the first 25 items per folder.
More details, visit:- Convert OST to PST free
Use the best OST to PST converter tool available by eSoftTools, this tool recovers and instantly converts the OST file into multiple formats like Office 365, MBOX, CSV, EML, MSG, and vCard, HTML, PST Outlook. This tool supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019 and supports all windows version smoothly, it does not require the installation of MS Outlook for the conversion of the OST file. Before converting the OST file into the other formats a smart preview is shown to the user to check the format. A FREE DEMO version is provided by eSoftTools, easily up to 25 emails can be converted into all formats.
Know more:- https://www.esofttools.com/ost-to-pst-converter.html
