OST to PST Converter Tool
Convert heavy size of Outlook .ost file with the help newly launched and most popular Vartika OST to PST Converter Tool. It gives you amazing process which takes fewer steps to convert all elements- contact/ calendar/ task/ notes/ inbox/ sent/ draft/ junk mails into multiple formats- EML, MSG, HTML, MBOX, vCal, vCard, PDF and EMLX. There is no file size limitation to convert OST file as well as you can import OST to Office 365 and Live Exchange Server.
Get Software- Vartika OST to PST Converter Software
Gives you smart and secure OST to PST Converter that converts huge size of OST file into PST and other provided formats. It is capable to convert all elements with safe manner into desired formats. It also import OST to Office 365/Live Exchange Server.
alex786
OST to PST Converter tool from Shoviv is providing a wonderful solution to convert OST files to PST, EML, and MSG format. It is also capable to migrate data from OST to Office 365 and Live Exchange server. You can also split large OST file during OST to PST conversion.
Read More:
http://www.bitdataconversion.com/ost-to-pst-converter.html
Exporting Mailbox items like emails, inbox, sent the item, draft, delete-items, attachment, calendar, notes, task (To, Cc, Bcc, Date, From, Object and Time) into PST to be a very easy task with the help of InQuit OST to PST Converter Software which is made up by using highly advanced algorithm for the conversion process. Before finishing conversion it shows the preview. It supports lots of file formats like PST, EML, EMLX, vCard, vCal, MSG, and MBOX to collect data after recovery. To see the working performance of this tool you can download its free demo version which allows you to access 30 emails in each and every folder free of cost.
Read More Details: OST to PST
devin
The OST to PST Converter tool is a very useful Outlook email conversion utility to make a trouble-free for the users to convert OST files to PST format. Easily convert your OST Files into PST as well as another file as EML, MSG, and MBOX format files.
More info;- OST to PST Converter
