OST to PST Converter Trusted Software
The best features of InQuit OST to PST Converter Software program are listed here:
• You can save your data into many amazing file formats like PST, EML, EMLX, MSG, vCal, vCard, and MBOX.
• Show recovered mailbox preview before the actual conversion work.
• It support MS Outlook version like 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016, 2019 (32bit & 64bit).
• Export password protected and encrypted data file in a secure way.
• Does not change the originality of the database.
• Support cloud-based application Office365 & Live Exchange Server.
• Before the conversion task it shows you the preview of a recovered mailbox along with Metadata like To, Cc, From, Date, Subject, Object, Time and Bcc).
• It gives 24x7 technical support.
Read More:
https://inquit-ost-to-pst-converter-toolbox.en.softonic.com/
Hazel
WholeClear OST to PST Converter efficiently exports all OST data into PST mailbox. It easily converts multiple OST data in PST format. It also converts emails, contact, to-do, calendars, and appointment from Exchange Online to Outlook. WholeClear OST 2 PST Converter moves the whole database after the conversion. It has an easy GUI which means the user doesn’t need to professional support to operate. It is compatible with all versions of Outlook and Window OS. It provides a Demo version for the user to check tool quality.
ruchika
Ignissta OST to PST Converter software is best Software which gives safe and secure OST to PST conversion results without any data loss.
Important Features for OST Converter
  1. No File Size limitations, convert large ost to pst files
  2. Capable to convert multiple file format like PST, Office 365, Vcard, EML, MSG and MBOX
  3. Split Option is there to convert large ost file to small size of pst file
  4. Supported all MS Outlook Versions like 2019, 2016, 2013, 2010 and 2007
Easy and Simple Process for OST to PST Conversion
Browse OST file ------------>
Preview Email Items ----------------> Export to PST files
If you are having trouble in the conversion of OST file to PST file format. You can use ToolsGround OST to PST Converter Software that will work without any issues for you. The tool assures you no loss of any data file and no compromise with file quality. This tool offers multiple formats for the OST file to MBOX, CSV, EML, MSG, vCard, HTML.
More Info:- https://www.toolsground.com/ost-to-pst-converter/
You can check out this eSoftTools OST to PST Converter software as free to try and get exceelent service to recover OST file to Outlook PST file and complete OST mailbox items such as emails, attachments, contacts, calendar, task, notes, journals and deleted folders also.
Find step by step OST file items just see how ost to pst converter software works smooth.
OST is a copy of the files stored on the server, while PST is a copy of the server files on the personal computer. Manual backup of the PST files is taken to archive files. It takes a copy of the email is saved on the exchange server. Moreover, a copy of the file is automatically updated on the PC, as an OST file. This helps to work in a cached Exchange mode, where emails are accessible while offline.
An excellent OST to PST converter tool is
ATS OST to PST Converter. It is a user-friendly interface with an advanced recovery algorithm. The tool supports all the versions of Windows including 8 and 7. This software supports all Outlook versions like Outlook 2019, 2016, 2013, 2010, 2007, 2003, 2002, and 2000. Export your OST data to all types of files -formats like MSG, EML, EMLX, MBOX, vCal, vCard, HTML, PDF, & NSF file. It has provided export data in Cloud App office 365 & live exchange, required only login details and you can access your data anywhere.
ATS converter tool not only recovers the mailbox but also contacts, calendars events, tasks, and much more within a short time. The tool revives the email details, such as the sender's and receiver's name, date, time and so on.
ATS OST to PST Converter tool
Therefore, OST to PST email software is the best software to convert and restore the PST files from offline OST.
For more information about this tool, you can access the official site Email, Data Recovery | Password Recovery | Contact Recovery Software
