OST to PST Recovery Tool
Taking the help of OST to PST Recovery program you can easily convert single as well as multiple files in a few little moments without any difficulty. It is very simple to use for everyone. The users can export their OST mailbox data into PST file format with full ease. The amazing features of this program are listed here:
• Support OS window version like 95, NT, 98, ME, XP, Vista, 7, 8, 8.1 and 10 (32 bit & 64bit).
• Show the preview of the recovered mailbox before the conversion.
• No size limit for the conversion work.
• Provide a demo version that allows you to convert 30 emails per folder free of cost.
• Gives 24x7 technical support.
• 30 days money back guarantee.
• Directly extract OST data into cloud-based application Office365 & Live Exchange Server.
Read more: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
To recover or migrate the data from OST file and save it into PST file format on the Mac system the user can go for OST to PST Converter for Mac Operating System. This software very much reliable and help the user to migrate the inaccessible OST file instantly in PST format on your Macintosh computer.
You can try the tool OST to PST Converter. I hope this utility could help you out to transfer OST files to PST format. The software is effective and takes very less time in the whole conversion. This application has one of the most simple and user-friendly interfaces. Free Trial version which transfer the first 10 items from each folder.
More info visit here:- https://www.toolsbaer.com/ost-to-pst-conversion/
jamesband
The OST to PST Converter tool is a very useful Outlook email conversion utility to make a trouble-free for the users to convert OST files to PST format. Easily convert your OST Files into PST as well as another file as EML, MSG, and MBOX format files.
More Info;- http://www.osttopst.adwages.com/
margkerberg
Use the very trustful ATS OST to PST Recovery application that is the best for repairing damaged OST file and recover the data. After the recovery process you can convert them into PST along with Emails, sent-items, deleted-items, drafts, outbox contacts, inbox, calendars, notes (To, Cc, Bcc, Subject, From, Object, Date and Time). Before converting the OST data into PST data file you can see the preview before the conversion. If you want to convert only selected data so you can choose those file which you want to extract. Apart from PST, it supports lots of file formats like EML, MSG, HTML, EMLX, vCal, MBOX, and vCard for preserving data.
Read More: https://www.bulkecommerce.com/store/ats-ost-to-pst-converter-software-159.html
Shoviv OST to PST converter gives the advantages to convert all data items (calendar, contact, task, notes, journals, appointments) into Outlook PST, Live Exchange Server, Office 365, and EML, MSG, and HTML formats without any intrusion. It provides secure and error-free conversion. It also provides the Mapping option, Split and Filter options and works with all versions of Outlook and Windows OS. Download its free trial version and convert or recover the first 25 items per folder.
For more details, visit:-
Convert OST to PST free
