Outlook express
herbalist
I am trying to erase Outlook express files. I followed the path: C:windowsprofilesxxxxapplication dataidentities{8A7BC380-FDDo_11D6-9734-AF5B06536E39}microsoftoutlook express*.dbx. I manually erased individual files (7 passes)including inbox,outbox,deleted,sent,and all the mail client files with the same names (Hotmail-sent items.dbx) etc. When I restarted and opened OE, I found the folders there. Upon opening the individual files with a text editor, all the data was still there. I dragged every one of those files to the recycle bin and erased the bin, 7 passes again. When I reopened OE, the files are still there. Are these stored elsewhere and being re-written? My OS is win98, OE version is 6.0. What is going on here? The eraser report says it was sucessful, but the files are still there and quite readable.
garrett01
Administrator
Staff member
Are you certain you erased your own pst files? each account stores its own pst files. Search the drive for *.pst
Was outlook shutdown at the time and did eraser report a completed erase?
Garrett
herbalist
Outlook express was not running at the time. The eraser report stated it was sucessful, listing total kbs erased and no failures every time. Searched with *.pst. Didnt find any files with .pst. All the OE files were .bdx. Is there another file type that could be an alternate storage location (.dat)? Noticed you said "outlook". Are we talking about the same program?
garrett01
Administrator
Staff member
Sorry I meant *.dbx. Did you try file find (Win+f) and search all drives.
The files just have to be there somewhere if you have all your emails intact.
Garrett
herbalist
Found another entire set of .dbx in separate user profile. When I erased, the files appear again, but are unreadable, Appears to be just system info. Now I just need to figure out how they ended up in another profile and why the interaction with mine. Its not the other users doing.
Use this efficient, fast and reliable DBX to PST converter. It finds and scans your DBX files for any errors and repairs them. Recover your lost files and imporatnt data instantly. You can preview files before conversion and select files that you want. It supports MS Outlook 2016, 2013, 2010, 2007 and compatible with windows operating system.
ToolsGround DBX to PST converter is advanced & effective software to convert Outlook Express .dbx files/ folders to Outlook PST format, with the help of this software you can convert all .dbx files to PST. It supports all type of .dbx folders like inbox, outbox, sent box, gets this reliable software to perform unlimited .dbx to .pst conversion without any restriction.
More Info;- https://www.toolsground.com/dbx-to-pst-converter/
samuelsarah
The DBX Converter tool can export your whole DBX files into PST format safely and install your files at the desired location. It’s doesn’t matter how long is your file and how big it is. Its easily working on all Windows operating Systems-10, 8, 7, XP, Vista, etc... The Converter tool allows users to open DBX files in MS Outlook, Apple Mail, Thunderbird, WLM, and other formats.
Visit here:- Convert DBX File with MailsClick DBX Converter to Export MS Outlook Express
davies
Outlook Express to Outlook converter is a quick, easy and affordable way to transfer emails from Softaken outlook express to office outlook. If you want a mail conversion tool to get your job done can be done with the help of this software.
hopemarha
Outlook Express DBX to PST migrator software which can simply convert DBX file into PST format without losing any files data and convert single as well as multiple DBX files at a one time. It performs a very swift and easy migrates action without reason any changes to the original files which are selected. You can try a free demo version software.
Visit here for more info:- Outlook Express to Outlook Converter
hopemarha
Are you thinking to change from DBX to Outlook PST? Both are used for emails, but they have different file formats. All email messages in Outlook Express are saved in DBX format, while Outlook stores all the mailbox data (mail messages, calendar, contacts, tasks, etc.) in PST format. I will suggest this tool DBX to PST Converter. It quickly converts DBX file to PST file which can be used in Microsoft Outlook.
know more info here:- Software to Convert DBX to PST
