Outlook OST to PST Converter- 2019
margkerberg
Outlook OST to PST Converter tool easily recovers all the data and convert them into the new accessible file format that is PST. The users can export their data into various file formats like PST, EML, MBOX, HTML, vCal, vCard, MSG and EMLX. It gives you an accurate result as per your requirement. You can export single as well as multiple files in a few clicks along with emails, contact, calendar, journal task, drafts, notes, deleted items, and attachment etc. It supports cloud-based application Office365 & Live Exchange Server. The application provides a free demo version to access 30 email items from each and every folder.
The Great Features
  • It supports the Office365 & Live Exchange Server.
  • Provide 24x7 technical support.
  • What is the size of OST or PST it does not matter because it easily handles it.
  • Does not create any complication in front of others.
  • Extract password protected and encrypted data in a secure way.
  • Does not lose any information.
  • The users can access lost and permanently.
Vartika Outlook OST to PST Converter which is powerful application that securely fixes OST file errors and safely transfer OST file to PST File along with mails, contacts, calendars and appointments. OST Converter Software allows users convert the OST files into PST Outlook file with maintains data integrity. Software works on all OST file versions up to 2016 and gives messages filtering option to filter the emails by dates for recovery with emails properties and attachments. It gives authority to import OST to Office 365 and Live Exchange Server.
Get Software- Vartika OST to PST Converter
OST to PST Converter software is a great opportunity for you if you are suffering from OST corruption problem. This tool gives you permission to recover and convert the overall data into PST file format. You can also convert single as well as multiple OST mailboxes into PST and other formats like MSG, vCal, vCard, MBOX, EML and EMLX according to your wish.
Perfect Data Solutions Outlook OST to PST Converter is convenient with latest and older versions of Microsoft Outlook. It permits you to convert OST to PST including all email properties (time, cc, from, bcc, date and subject) with attachments. Without need of any extra effort you can Convert OST to Office 365, EML, MSG, MBOX, PDF and HTML.
alex786
Outlook OST to PST Converter tool from Shoviv is providing an advanced solution to recover corrupted OST files and convert OST to PST format. Using this tool, users can also export their data from OST to Office 365, Live Exchange server, EML, and MSG. It has a free trial version and a good technical support team as well.
Know More: www.bitdataconversion.com/ost-to-pst-converter.html
