Outlook PST Repair tool
barsewatson
I would like to suggest you to use of third party Outlook PST Repair tool to successfully recover all PST mailbox data like emails, tasks, appointments, journals, decorated text, email properties, zipped attachments, notes, drafts, scheduled tasks, etc. from corrupt PST files. The software Operates in two recovery modes: Standard & Advanced. Get more information, visit from: http://www.fixpstfile.net
If the PST file is corrupt, you should use the Inbox Repair tool, commonly known as scanpst.exe utility. It comes as a built-in repair tool with MS Outlook client. By using the scanpst.exe utility, you can scan corrupt PST file for errors and fix them with ease. If you don't know how to use the scanpst.exe utility, you can refer to this blog post - How to Recover Outlook Mailbox from Corrupt PST?
If the scanpst.exe utility fail or doesn't repair PST file, you must use a professional recovery solution.
paul hogan
In my opinion, first, you should try to run SCANPST which is a free tool developed by Microsoft to repair corrupt Outlook PST File.
Location of SCANPST:
Microsoft Outlook 2016
32-bit Windows C:\Program Files\Microsoft Office\Office16
64-bit Windows C:\Program Files (x86)\Microsoft Office\Office16
64-bit Outlook C:\Program Files\Microsoft Office\Office16
But, SCANPST fails to repair highly corrupted or damaged Outlook data File and also takes too much time to repair, if you have large PST File. In such a case, you need to move on any third party source. I would like to suggest you SysTools Outlook Recovery to repair corrupt PST file. You can also break your large PST file into smaller PST's by date, year, folder and size with the help of Split PST option.
bittlesanc
Download PST Recovery software which provides you best platform to recover and restore damage Outlook PST files such as email, calendar, notes, notes and task and repair into Outlook PST, EML, MSG, MBOX, HTML, and save it new healthy formats in required location. I would suggest you must use this software once before purchases other company software.
Get more information:
http://www.bulkecommerce.com/store/ats-outlook-recovery-software-164.html
copegroups
The corruption of PST file is due to file size limitation i.e. 2GB. Enstella Systems provides PST Recovery Software to recover PST file from above corruption issues and allows user to save PST file into ANSI and UNICODE file type. This software recovers password protected PST file and facilitates message filter option to search emails between two selective dates such as “start date” to “end date”. You can break outsized PST file into different size PST file upto 5GB. The Demo version of this application to restore 20 emails per folder into each format at free of cost.
Download Demo Version:- Enstella PST Recovery
Neil Pattrique
There are many vendors in the market which provide you PST repair or recovery tools, and most of them are available with free demo version. By using demo version, you can check the preview of your mailbox content which you can recover from the corrupt PST file before purchasing the software. If you're satisfied with the results, then only you should purchase the software.
Tirtha8586
Would suggest you to give a look on this youtube video.
Where they have mentioned some good techniques to resolve corruption in Outlook OST file
With a comprehensive and secure Outlook PST repair software, you can easily solve Outlook PST corruption issues. The software also helps to recover deleted or permanently deleted Outlook mailbox items from corrupted PST file. You can also use it to move PST file into several other formats like EML, RTF, MBOX, IMAP, MHTML, PDF, PST, MSG, TXT, DBX, and HTML. To know more, visit: https://pstrepairtool.blogspot.in/2014/01/perform-pst-repair-and-retrieve-outlook.html
There are no any such tools for freely repair OST file online. If you want to converting items from an OST file into Outlook then you can try PST Repair software that allows to export your some emails from an OST file into PST format. You can try demo version of the software online that allows to export your 10 items from OST file into Outlook PST format. If you are satisfied with demo version then purchase full version at lower cost. Visit for more info : http://www.osttopstapp.com/pst-repair.html
anonymous
To import PST to Office 365, you can use Emailsoftwares Import PST to Office 365 software. The software can very easily migrate healthy PST or OST file to Office 365
and Exchange. The software helps to import PST files to mailboxes, archive mailboxes, and public folders of Office 365 and Exchange. For more information, visit:
In order to repair corrupt emails and other PST file contents, you can utilize an Outlook PST repair software.
Make use of eSoftTools Outlook PST Recovery tool to easily repair corrupt PST file and recover all PST database like emails, contacts, chats, tasks, notes, journals, and appointments to a new PST file and several other file formats such as EML, EMLX, MSG, HTML, MBOX, and Office 365 cloud. A free trial version of this software is also available on the given link to export 50 items from every folder of PST file to other file formats.
Get More Info:- Outlook PST Recovery
Gioisoiap
Updated tool to repair Outlook-Eelphone Outlook Repair
1. Load corrupted Outlook files to the tool
2.Select the damaged Outlook files to repair
3.Select the output format and the save folder of repaired Outlook files
In three clicks, we can repair corrupted Outlook documents.
