Recover and Convert OST to PST
ralphmiller
Recover Outlook Mailboxes data from inaccessible offline OST file and convert to Outlook PST file using OST to PST Converter Software. This software is an advanced tool which allows you to convert OST to many other multiple formats. Converted data as PST file with OST Converter tool is easily accessible with all version of MS Outlook software.
  • Convert OST to PSt, EML, MSG, MBOX, EMLX, vCard & vCal formats.
  • Repair and scan corrupt OST file.
  • Recover Outlook mailboxes Inbox, Outbox, Sent Items, Drafts, Calendar, Contacts, Tasks, Notes, Journals etc.
  • Restore emails with all meta properties like to, cc, bcc, subject, date-time & attachments.
  • Maintain the same folder structure after conversion to other formats.
  • No limit of the OST file size for conversion.
  • No risk of data loss.
  • Allows previewing all emails and other data before conversion.
  • No Microsoft Outlook installation required.
  • Directly Export recovered OST data to Office 365 account and Live Exchange Server.
  • Supports OST file from all versions of MS Outlook 2016, 2013, 2010, 2007 & older.
Read More- TechNet OST to PST Converter Free Download- Convert OST to PST
Export OST to PST tool helps you to repair corrupted, damaged OST file into PST file. And can instantly convert OST file into PST file and into multiple different extension. OST to PST conversion enable to recover single email and multiple items. Also user can see preview before saving Fresh PST file.
For repairing and recovering corrupted or damaged OST file use Vartika OST Converter which has ability to re-access OST file elements and then convert into various formats- EML, MBOX, MSG, EMLX, vCal, vCard, HTML and MSG including all email header information (to, cc, bcc, from, date, time and subject). OST to PST Converter has capability to import OST to Office 365 and Live Exchange Server without create any problem.
Get Software-
Convert OST to PST
There are lots of third party OST to PST conversion software available in the market that can easily do this task. But for the Mac users, I would like to suggest such an application, name as Mailvita OST to PST Conversion tool for Mac which helps to repair corrupt OST file and recover the stored data without facing any issue. This is a smart tool to use for this migration and the data remain the same.
alex786
To recover and convert OST to PST, EML, and MSG format in a hassle-free manner, Shoviv OST to PST Converter tool could be the best option for you. Because this tool provides a quick, easy and secure solution to export OST to PST, Office 365, and Live Exchange server. It has a free trial version and a good technical support team as well.
Read More: www.bitdataconversion.com/ost-to-pst-converter.html
Perfect Data Solutions OST to PST Converter authenticates you to recover highly corrupted OST file with every single bit of information. When it completes recovery procedure then allows users to convert OST file to Outlook PST/ Office 365/ MSG/ HTML/ PDF and MBOX with all internal components in one go. It gives you easy compatibility with Windows versions up to 10 and MS Outlook versions up to 2019 (32 and 64 Bit).
