Recovery Software for iPhone
DavidMcMillian
Wondershare Dr. Fone for iOS is a almighty tool to recover iPhone lost data, it can help to scan and retrieve them from iTunes or iCloud backups if you have backup your iPhone to iTunes or iCloud or it can helps you retrieve contacts directly from your device. Besides it is completely compatible with iPhone 5s/5c/4S/4/3GS and it can retrieve 18 types of content like photos, videos, contacts, messages, notes, call log, voicemail, voice memos, calendars, reminders, etc.
For download this Software search this link " Softmagnat(DOT)com/wondershare-drfone-for-ios " on Google ...
sakumi30
If you own an iPhone and one day it stuck in recovery mode, you can use the Tenorshare ReiBoot to fix it. It is a professional free tool to help you enter or exit recovery mode of iOS devices, including iPhone, iPad or iPod. So as the best iPhone recovery mode software for Windows, you can use it to fix your iPhone. So if your iphone 6 plus won't connect to itunes when in recovery mode, you can use it.
See more at HERE->>
SarahChris
There are so many software for you to restore your iPhone deleted data, and I found some features of them. There are different solutions to different problems, in other words, you can apply different products to solve some types of trouble.
lisaab
To recover lost iphone data, we can use an iphone backup extractor to recover the lost file by extracting from the iTunes backup file, try Coolmuster iPhone Backup Extractor, it could recover the latest backup file.
lucylla
Thank you
Pleake
PhotoRec is an open source multi-platform application designed to recover lost files including video, documents and archives from hard disks, CD-ROMs, and lost pictures (thus the Photo Recovery name) from digital camera memory. It can be used to recover lost pictures, contacts and more from a Jailbroken iPhone.
kaoler1
If you have made a iTunes backup before, you can connect your iPhone to iTunes, right-click on your device and select the backup to restore, else you can use iPhone data recovery, it not only can extract iTunes/iCloud backup, but also can directly scan your phone and recover deleted data on iPhone, just need 3 simply step.
Askiyytr
Coolmuster iPhone Data Recovery is used to recover accidentally deleted data . You can recover deleted iPhone data : Text Messages, Contacts, Notes, WhatsApp Messages, , Call history and Calendar events ,Notes etc. And you can also extract data from backup files .
Alenliu
Pro iPhone Data Recovery can help us recover lost files from iPhone in one click, which allows you to easily get back the lost files from iPhone as long as your iPhone has not been broken into pieces. All files can be well supported including contacts, messages, photos, music, reminders and many more.
alanmore
If you would like to recover data from iPhone, you can restore your iphone with backup file. By this way, you can easily get back the data you want to recover. If you don't have backup file, you can also use iPhone Data Recovery software. It can scan your iPhone deeply and find the deleted data for you. You can recover deleted photos, videos, contacts, call history, notes, reminders, calendars, voice memos, voicemail, bookmarks, Whatsapp messages and other deleted or lost data from your iPhone. You can learn how to recover deleted notes on iPhone here.
Edom
FoneDog, It can recover iPhone data and Android Data.
  • Recover lost contacts, messages, photos, notes, videos, call logs and even app data from any iOS device.
  • Recover lost or deleted data from iPhone/iPad, iTunes or iCloud.
  • Support all iOS version (includes iOS10.2 ) and models (includes iPhone 7)
Keitha Meyerson
stephanic
Hello,
There are many software that are available to restore your lost iPhone data. Among several, iOS data recovery software is the best which can help you to recover your lost data from iPhone. Not only from iPhone but it supports iPad as well as iPod Touch. No worry how your data is lost but it has the ability to rescue all your data lost from your iOS device.
For more information, better visit the link which will guide you the best. http://avoid-ios-10-update-failed.sitey.me/ios-blogs/ios-10-2-data-recovery
