Remove Screen Lock from Android Phone without Data Loss
MagloireHunt
If you forget the screen password or your smartphone is out of order, you will need Dr.Fone for Android to remove the screen lock. It removes the pattern, fingerprints, PIN and password without data loss.
The program only workable for several Samsung Galaxy devices like:
Samsung Galaxy Note II, Note3, Note4, Note Edge, Note5, Note5 Duos, Note8
Samsung Galaxy S3, S4, S4 Active, S4 LET-A, S4 Mini, S5, S5 Duos
Samsung Galaxy Tab 2 7, Tab Pro 10.1, Pro 8.4, Tab S 8.4, Tab2 10.1
BellyBlack
Android phones sometimes will be locked accidentally when people forget their passwords or enter the wrong password for too many times.
Luckily, RecoveryTool Android Data Recovery is here to help you to unlock an Android phone without Any Data Loss.
AmandaColey
Although factory reset your phone in recovery mode can remove the lock screen successfully, it also wipe your phone data. So, any other better way to bypass the phone without losing important data?
It’s possible to unlock the phone meanwhile keep the data in it as well. At this time, you need an Android Lock Screen Removal toolkit.
The FORecovery Android Lock Screen Removal toolkit is a professional tool for users to fix system issues and restore a series of data of phone. With a simple click, this software makes it easy to unlock your Android phone, besides it also guards list of your data. Follow us. Before you start, download the toolkit from the official website and install it on your computer.
MagloireHunt
Also here is another video about unlocking screen lock from a Samsung Galaxy Android phone without data loss.
Salimasidas
Eelphone Android Unlock is one professional tool to remove Android screen lock without password. With detailed guide, what we should do is clicking, connect Android phone to computer, launch the tool at the same time, the tool will guide us to remove screen lock without password.
Related guide: Unlock Samsung Phone Lock Password
