Safe Exchange EDB to PST Converter
InQuit EDB to PST Converter coupon code software is easy to use for the conversion of EDB to PST. With the help of this utility, you can access your data in a safe manner without losing any information. This software does not create any difficulty while you convert the data. It has a simple interface which makes it easy to use.
It supportable with MS Outlook version 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. It backing the version of MS Exchange Server up to 2016. With the aid of this tool you can convert encrypted and password protected file without any hassle.
There are no limitations of size for converting the data from EDB to PST file format. It is capable to migrate EDB data into Live Exchange server &Office365 which is the cloud-based application.
The users can also migrate single as well as multiple EDB file at a one time. You can download its free demo version which allows you to access 30 emails per folder free of cost.
Read more: EDB to PST Converter
There are many recovery tools popular in the market to recover EDB file or folder from damaged EDB file in few clicks but SysOZ EDB to PST converter software one of the best recovery tool which gives more facility than another setup. Use the demo version of this program to watch their performance then download the full version after your satisfaction. This program gives 100% conclusion after the repairing process. You are free to convert your data into formats like MSG, HTML, PST and EML.
Read more: Download Free EDB to PST Converter
