Smart method EDB to PST Converter
Don’t waste your precious time by using non efficient tool for of EDB file converter. Just use SysOZ EDB to PST Converter. Now you will ask why to use Exchange EDB to PST because it has so many features that makes your work very easy and fast and not only this, the tool is also used by the most of the big companies for data recovery and also by most of the IT professionals. This software has so many features that makes it best. This tool supports various formats like PST, EML, MSG, and HTML. This also supports various cloud based application like Office 365, Live Exchange Server. This tool is compatible on the various latest versions of Microsoft Windows 10, 8.1, 8, 7, Vista and XP. You can also avail free demo version of this software and can have access on the various features of this toll for free.
Read more: EDB to PST Converter
Free demo version software is also available.
Just $129
If you want to convert EDB data files to PST and want the best and smart way. So I would suggest to try the third-party tool, Shoviv EDB to PST converter. It provides the best results and error-free conversion. The software scans your data files, mailboxes, and converts or recovers the files with the proper manner. This software is considered as the best software for EDB recovery as it has multiple options available for Exchange recovery like It converts the multiple EDB mailboxes to PST Outlook, Office 365, and Live Exchange Server and also export data into EML and MSG formats. It provides the free trial version of this software. With the help of this trial version, you can check the efficiency of the software and migrate the first 25 items per folder.
More details, visit:- EDB to PST Converter Software to Convert EDB to PST File
