Smart OST to PST Converter Software
The Interesting Key features of InQuit OST to PST Converter are mentioned below:
• Expert for converting the OST data into PST data file.
• Does not create any difficulty in the conversion.
• Supportable with all the version of OS Windows 95, NT, 98 and all the above version up to 32 & 64 bits.
• Divide a heavy file into several small files.
• Show the recovered mailbox before finishing the conversion.
• Keep the originality of Meta properties like To, Cc, Bcc, From, Date, Time and Objects.
• It backing Outlook version 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019 also included.
• Migrate the data into PST, EML, MBOX, vCal, EMLX, MSG, and vCard, HTML file format.
Download OST to PST Converter software is a great designed tool that export OST data to PST format. By this tool, the users can recover and access inaccessible OST items such as emails, contacts, notes, journals, tasks, calendars, etc. in an effortless manner. The application works effectively with all editions of MS Outlook including Outlook 2003, 2007, 2010, 2013, 2016, 2019, etc.
More Info visit here:- https://www.datavare.com/software/ost-to-pst-converter-expert.html
Using SysOZ OST to PST Converter program user can easily re-access damage OST emails data within few minutes. This is the big opportunity for them to convert all the data into PST file with complete emails data. This is made up by using the highly advanced algorithm which makes it super-fast to do recovery of OST data. Support all the version of MS Outlook like 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. Splitting the large converted PST file into multiple small PST file. Save resultant file into PST, EML, EMLX, vCard, vCal, MSG, MBOX file formats.
ruchika
I would like to suggest you Ignissta OST Converter software which helps you to repair and recover Damage OST file and Convert to PST file.
Lot's of Features with Ignissta OST to PST Converter
# OST to PST Conversion with No Files Size Limitations
# Provide 100% safe and secure conversion results with 100% Data Accuracy
# Capable to convert Multiple File Format such as PST, VCARD, Office 365, EML, MSG and MBOX
# Supported all MS Outlook Version 2019, 2016, 2013, 2010 and 2007
Download Trail Version and Convert OST to PST File https://www.ignissta.com/ost-to-pst-converter/
Browse OST file ------> Preview Mail Items -------> Export to PST
