Split Archive PST File of Outlook 2016, 2010, 2013, 2007 Mailbox
MicMatz
How can i split archive PST files of MS Outlook 2016, 2010, 2013, 2007 Mailbox because over sized PST files does not open in Outlook........
Efficiently splits a large PST file into smaller and manageable PSTs, based on specified PST split criterion, such as Date, Size, Mail Id and Folder.The software maintains data integrity of the original PST file. After splitting a large-sized PST file into smaller pieces, they can be easily accessed with MS Outlook and are completely independent of original PST file. Just need to Download Split PST Tool
alex786
To split large size of PST file into multiple PST files, I would recommend you try Shoviv PST Splitter software. This tool works smoothly with all MS Outlook version and allows users to split PST file by size, by date, by folder, and by year. To know its feature and working process download a free trial version of Shoviv PST Splitter tool.
1080
camilia
Try this amazing Outlook PST Splitter to split your archive PST files of MS Outlook 2016, 2010, 2013, 2007 Mailbox. The tool can easily break large or oversized Outlook PST file into small files by Date, Size, and Folder. It supports all the editions of MS Outlook and Windows OS. The advanced software is fully capable to divide Password Protected Outlook PST file.
Visit here to download the latest version of Outlook PST Splitter: Split Oversized PST File into Small PST - PST Splitter
