Split large PST file into smaller parts
How to Split large PST file into smaller parts..? How to split oversize PST file in Outlook 2016.?
This is one of the most reliable ways to split oversize or large PST file into smaller parts to avoid the 2 GB PST file corruption issue. This KDETools PST Splitter application is 100% safe and secure to download and run and also following these top software features:
  • Split Oversize PST file into smaller parts
  • Split Large PST file by Size MB/GB
  • divide / split Outlook PST files by Date, Year
  • Split large PST file by Folder/Items
  • Split large PST file into Outlook 2019, 2016, 2013, 2010, 2007
  • Split PST files without install Outlook
Also Download Free: http://www.pst-splitter.com
ruchika
PST Files are bit a complicated subject because it contains emails, contacts, calendar and many more. There are different extensions for all PST components. Thus, in conversion or any kind of data practice in the PST folders can cause data corruption. So if you want Split Large PST files without corrupting it, then I will recommend you to for some automatic tools.
Here in my point, Ignissta PST Splitter is the reliable and best tool to Split Large PST File. Now with one software you can merge PST files as well as split PST files easily. This tool comes wth
  • 100% secure and complete solution
  • Life-time customer support
  • Demo version available
  • Several advance version including split and merge PST as per date, time (user choice).
  • Many more ---------->
Split and merge PST files with Ignissta PST Splitter & Merger Download Software with This Link https://www.ignissta.com/pst-splitter-merger/
Easy and Simple way for Splitting PST File
1. Browse PST File -----------------> 2. Select Split Option --------------> 3. Click to Splitting
Split PST for Mac Software is an excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, Year, folder, and email id, and defends them from any corruption issues because of file size limits. It is fully capable of splitting all MS Outlook items such as folders, contacts, calendars, journals, email folders. The application makes you sure that no actual data deleted during the process. This Software supports all Mac OS versions.
