Split NSF File
Marky
Are you looking for suggestion to split NSF file? So, here we introduce NSF Split that helps you to gather the more information about to split NSF file by their size, folder, year and date. NSF Split Tool is well-suited for all Windows editions such as 7, 8, 8.1, 10, OS, Vista an so on. This tool also has the ability to break NSF password-protected files if you have a password of that particular file. Utilization of free trial version facility helps more to collect the brief information about the NSF Split.
alex786
For splitting large size of NSF file into Multiple Small NSF files, I would suggest you try Shoviv NSF Splitter software. This software provides multiple options to split your NSF file such as split by size, split by date, split by folder, and split by year etc. It has a free trial version and a good technical support team as well.
Download Trial Version
