Split PST File - How to Split Large PST File
MicMatz
How can i split large PST files of MS Outlook into simple or small pst file format.
Rohan Wiese
Split PST File tool to speedily split large MS Outlook PST files into smaller PST files embedded with entire email properties. This software has advance feature that keep integrity of file and data after splitting PST files. Split PST tool is able to split any size of PST files according to date and years.
Thanks & Regards
Rohan Wiese
Riya Thomas
Hi,
Nowadays, most of the Microsoft Outlook users are searching for the solution “how to split large PST file”? There are so many blogs available to provide the solution for this query. I would like to share one article which provides the manual and automated solution to divide oversized PST file. Please refer the following link to get the details.
Visit: https://writeapp.me/christ9379/note/resolve-large-pst-file-issue
Thanks & Regards
Riya Thomas
selvi
Hi,
You can Break MS Outlook PST file very easily and conveniently, there is no such size limit because you can split large files of Outlook within no time.
Thanks
Efficiently splits a large PST file into smaller and manageable PSTs, based on specified PST split criterion, such as Date, Size, Mail Id and Folder.The software maintains data integrity of the original PST file. After splitting a large-sized PST file into smaller pieces, they can be easily accessed with MS Outlook and are completely independent of original PST file. Just need to Download Split PST Tool
The answer to “how to split large PST file” is with eSoftTools. With eSoftTools PST recovery tool, one can recover PST file and split PST file into many smaller PST files where the size of the new files is defined by the user. It is available for free and is compatible with all types of PST files (any version and size) and Windows OS. It works well with ANSI and UNICODE PST records for Outlook recovery.
Know more here: Get eSoftTools Outlook recovery Software to repair PST file | Outlook Repair
Using a PST Splitter, you can easily break your large sized PST files into multiple smaller ones.
alex786
Bitdataconversion for Split PST file software is an advanced tool which provides an easy and safe solution to split large PST file into multiple small PST files without tampering any content. Using this tool, users can split PST file by size, by date, by year, and by folder. To know about software functionality, users can download a free trial version of this tool.
Read in Detail:
http://www.bitdataconversion.com/split-pst-file.html
Try one more best solution named KDETools PST Splitter to split over-sized PST file into multiple smaller parts.
This is a most reliable and 100% secure PST Splitter tool which provides an 100% easy solution to split large PST file into multiple small PST files by follow these features:
  • Split PST by Size
  • Split PST by Date
  • Split PST by Year
  • Split PST by Folder
  • Split PST by Select Items
It has a Free trial version: http://www.pst-splitter.com
1497
ruchika
I would like to suggest Ignissta PST Splitter and Merger utility tool which provide 100% fast, safe and secure results. You can split pst file with following features.
Split PST file Features
# Split PST File Size wise (MB or GB)
# Split PST file Date Wise
# Split PST file with specific Email ID
# Select Mails and Split
This software also support and capable to merge multiple pst file to single pst file and also remove duplicate emails items while merge pst file
Merge PST File
# Merge Multiple PST file to New PST file
# Merge Multiple PST file with Exisiting PST file
Remove Duplicate Emails
While Merge Multiple PST file you can remove duplicate emails.
Download Trail Version and Split PST File with first 50 Emails items https://www.ignissta.com/pst-splitter-merger/
