SQL Database Recovery Software to Repair Corrupt & Damaged MDF
anonymous
Another SQL Repair tool is the most trusted and effective third party software, allows its user to recover data from corrupt or
damaged MDF/NDF files of a SQL Server. The software is compatible with all MS SQL versions, including 2016, 2014, 2012,
2008 R2, 2008, and 2005.For more information about the software
Mark Dyson
Hi,
There are many manual methods that you can try. But easiest is to to use a third party tool to repair the database.
On such great tool is SQL database Recovery Tool.
With this tool you can easily recover corrupt MDF and NDF files.
