Robinsan Shaw
A .xls file format used to store excel field data of Microsoft Excel Application. Data stored in cell form and the different formatting condition can be applied to it but there is another use of file format that can help Outlook user to save their big problem to save thousands of contacts details quickly. To transfer Excel to Outlook 2007, 2010, & above latest edition such as Outlook 2013/2016 can be much easy.
To do this conversion user need to first create a new excel file and save all user details into Excel format properly.
Read more at:- Transfer Contacts from Excel to Outlook
Download eSoftTools Excel to Outlook Contacts Converter Software have import excel to vCard(.vcf) file without outlook software. This Software allows convert .XLS, .XLSX & CSV to MSG outlook, PST outlook & vCard(.VCF) file with latest version of excel to outlook contacts upto 2019 and windows version upto 10 (32-bite & 64-bite).
Read More:- http://www.esofttools.com/excel-to-outlook-contacts.html
jamesband
To export the data from Excel to Outlook you can make use of Excel to VCard Converter software which will migrate the Excel data into vCard format which can be easily imported into Outlook. By using this tool the user can quickly convert the data into vCard from Excel. There is no lacks or error in this tool. Visit:- https://www.softaken.com/excel-to-vcard-converter
