Tmzmo623
Do you looking for a simple way to transfer Huawei contacts to Samsung Galaxy S8/S8+, just like:
sync contacts from Huawei Mate 7/8 to S8/S8+
sync contacts from Huawei P7/P8/P9 to S8/S8+
sync contacts from Huawei 8 to S8/S8+
sync contacts from Huawei 6X to S8/S8+
sync contacts from Huawei 5C to S8/S8+
If you planning to buy a new Galaxy S8/S8+ to replace the old Huawei phone, and wanting to sync all your contacts between the phones, then you can miss the Phone Transfer.
Phone Transfer to help move data between Android and other devices without any quality loss. With its help, you can easily transfer contents including contacts, music, photos, videos, apps, and more. So, you can easily transfer anything you like from your old Huawei phone to Samsung Galaxy S8/S8 Edge by using this tool.
alanmore
Hey,
I think it's easy to do that if you have Phone Transfer software. It can connect your huawei and Samsung phone at the same time and then transfer files between them. You can transfer contacts, photos, videos, messages, calendars, apps and app data from Huawei phone to Samsung phone.
Cassatty
Coolmuster Mobile Transfer helps a lot on moving contacts, photos, videos and text messages from android to android, which is conducted with simple operation and high efficiency. You can achieve what you want with only one click. So you can use it to transfer contacts from Huawei to galaxy s8.
How to transfer contacts from LG to Galaxy s8
Maple Bolon
No need to utilize computer, you can directly transfer contacts between the devices with a free phone to phone transfer tool. Download the app on the mobile phones, go to "Contacts" and choose contacts to transfer. It is pretty easy and convenient. Give it a try!
etanmccarty22
This dr.fone - Switch can help to transfer contacts from HUAWEI to Samsung Galaxy S8/S8+, here is a video about dr.fone for Android
