ethanbrowns
If you are absolutely beginner and don't have any prior knowledge of using EDB to PST Converter, then obviously you need a good program that can solve your problem with it that can guide you correctly about the conversion process, and I would suggest you to try InQuit EDB to PST Converter which is made using the best algorithm The conversion task for the Exchange EDB file to PST file format.
This conversion tool is the best tool that also gives you an option to convert Exchange data in various formats like PST, EML, MBOX, EMLX, vCard, vCal and MSG. Apart from this, it also allows you to convert large EDB file to PST as per your requirements.
This tool allows you to export data directly to the Office365 and Live Exchange Server cloud-based application which is a very important additional feature in this application. This tool does not consume more time during the conversion task. Do not make any changes to the database during the conversion process.
It is always compatible with all versions of MS Outlook like 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. And the best thing is that all these amazing features are equipped with one tool that is also available for 30 days free during this period, it will allow you Access 30 email items in each folder at no cost.
Read More: Free Download Exchange EDB to PST Converter
