vMail OST to PST Converter
ralphmiller
vMail OST to PST Converter is a useful tool to execute email conversion in Outlook from OST file to PST format. This software has very easy to use interface with many advanced features. OST to PST Tool can recover inaccessible Outlook mailboxes from corrupt and encrypted OST file and export as easily accessible PST file.
Features Include.
  • Convert OST to PST, MBOX, EMLX, MSG, EML, vCard & vCal formats.
  • Supports OST file created by MS Outlook 2016, 2013, 2010, 2007 & more.
  • Recover every Outlook components without losing any data.
  • No OST file size limit for conversion to PST.
  • Directly Export data from OST file to Office 365 & Exchange Server.
  • Maintains email properties and original folder structure after conversion.
  • Allows previewing recovered emails from OST file before actual conversion.
Overall, vMail OST to PST Converter is a very capable option for a simple, lightweight and advanced OST to PST Converter software.
Visit Here- OST to PST
Get download OST to PST Converter is a proficient and well designed program that can convert all the OST files into PST safely and quickly. It is a well-designed software program that conducts OST file conversion of all the emails with an attempt to save your time. It allows you select only specific folders to convert files and you can get only those mailbox items you want in your Outlook PST data.
margkerberg
Try to Bulkecommerce OST to PST Conversion tool to fix all corruption issues and restore corrupted OST file into PST outlook file formats. he is the best recovery & Converter tool to convert OST file into office365, Live Exchange server with MSG, EML, EMLX, MBOX, vCal, vCard and HTML file formats. this software capable to restore bulk OST file into Outlook PST file with the split large amount of PST file to the small size of PST files.
696
Demo version software allows freeware saved 30 emails in each & every folder in each format
More info visit: Manually free Method to convert OST file into PST file
Vartika OST to PST Converter joined with exclusive features and helps user to convert OST file into PST formats. This program also converts all emails with attachments, journals, task, notes, appointments, calendar and contacts etc. In addition, it provides multiple conversion formats like Office 365, Live Exchange Server, EMLX, vCal, vCard, HTML, EML, MBOX and MSG and applicable with all versions of Windows and Exchange.
Get Software-
OST Converter Software
eSoftTools OST to PST converter tool is the best mode for converting the OST file into different formats like PST Outlook, CSV, EML, HTML, MBOX, vCard, MSG, Office 365. This tool auto-detects the location of the OST file and recovers the data to access the information, for the secure recovery it shows the smart preview to the user. It supports all file version like 2000, 2003, 2007, 2010, 2013, 2016, 2019, to convert OST to PST this tool does not require installation of MS Outlook. A FREE DEMO pack is available to the entire user, by this demo 25 emails can easily be recovered and converted.
For Quick and hassle-free OST to PST conversion, try Shoviv OST to PST converter tool. The tool Shoviv OST to PST converter provides the facilities to recover the deleted and corrupted OST Items and convert into PST Outlook, Office 365 and Live Exchange Server. It also exports data into EML, MSG, HTML formats. The tool shoviv OST to PST converter provides Fast and 100% accurate results for OST to PST conversion. Its special work to restore deleted OST data Items and back into the previously used format without changing the data. It recovers the permanently deleted and corrupted OST data items such as email, contact, task, calendar, Journal, etc. Download its free trial version to check the efficiency of the tool and convert the first 25 items per folder.
More details, visit:-
Convert OST to PST free
InQuit OST to PST Converter plays very important role in the conversion of OST to PST file format. With the help of this utility, user can split their large OST file into several small PST file as per their need. The size of the OST file does not matter for the conversion purpose. This software can export encrypted and password protected file in a safe manner. The GUI makes it easy to use for everyone even technical or non-technical users easily operate it and transfer their data into multiple file formats like PST, EML, MSG, vCard, vCal, EMLX, MBOX, and HTML.
Read more Info: https://download.cnet.com/InQuit-OST-to-PST-Converter/3000-2369_4-77972350.html
If the user stuck in moving the data fie into PST from OST file format of any supportive email client or exchange server. The user can make use of the Softaken OST to PST Converter software which will help the user to migrate the data in bulk from OST format to PST format on any version of the Windows and works well with all version of the Outlook. The user doesn't requires much technical knowledge for using this tool to export the data from OST to PST format.
