Eraser 5.87-beta 1 Portable
• Page 1 of 2 • 1, 2
Hello all,
I've got a Portable version of Eraser set up and compiled for Win32, you can find that here: http://eraser.sourceforge.net/Portable.zip. Extract it and run Eraser.exe, settings will be stored in an INI file in the same directory.
Usual hashes:
MD5: c9ed6120b7dd94ef5f6228b9b9570459
SHA-1: 16aae2e6779872b7d443650f4ddbbe8480df8684fe39d7450c49fa2f1de8e6ca92b7772ac3bebbbb774a86bbf4214314ed86a6a0
SHA-256: e49e50e9209f5d6a8c54d4b569040dfea1532783526632364f4f9c53c4e0111d9b4de47855
WHIRLPOOL: 514ccf815b5931abcc5cb7f07a792a6095824b22c566d368b21910
The bugs mentioned in the earlier thread about the beta installer has not been fixed, I'll fix them soon and release a new version. Do test the portable version for registry keys and files left behind on the computer and for any bad or missing functionality and report back.
Thanks!
Usual hashes:
Thanks!
Joel - Eraser DevTeam
I've re-released the Portable version.
New hashes:
MD5: 9873473fff3e04b84f76e17b176406d5
SHA-1: 9648fe6b6d7be1cd524374a345c7ae7a0263d303
SHA-256: 3822f8c77c75611d6ab6bcc686107f9eed7b836ce677bcd52afd2d7644de07cc
Whirlpool: 5e800e28215bb1926dae42740c672c1676b2068d97e4082b6ed8444bbcb70ede1de85b776e9e90c3ef4ab7e5208efd99ad6cf10e4832e0dd0d8b3f8bf5df8660
This fixes a path error for storing default.ers
New hashes:
A few (3) last registry keys and this will be completely portable/stealth.
[HKEY_CLASSES_ROOT\Eraser.Document]
[HKEY_CLASSES_ROOT\Eraser.Document\DefaultIcon]
[HKEY_CLASSES_ROOT\Eraser.Document\shell\open\command]
[HKEY_CLASSES_ROOT\Eraser.Document\shell\print\command]
[HKEY_CLASSES_ROOT\Eraser.Document\shell\printto\command]
[HKEY_CLASSES_ROOT\.ers]
[HKEY_CLASSES_ROOT\.ers\ShellNew]
Regards.
Regards.
- chezduong
The Eraser code do not have references to these entries. They don't seem to be created by the running of Eraser. Perhaps they have been left behind from an old install? Do check and get back to me.
EraserL is already standalone, in the normal distribution. You can install eraser on a trusted computer and use EraserL from there.
Sorry, poor wording I guess. I meant a portable version of EraserL that doesn't require the VC++ libraries to be installed (ie statically linked). Just like the Eraser version in this thread. I just need the commandline functions for scripting and automation etc.
Unless I'm mistaken and this portable Eraser still DOES require the runtimes to be installed?? Can you clear that up for me?
- wraithdu
Ah. I see. I'll do that.
Yeah the portable ones do not need the runtime.
Re: Eraser 5.87-beta 1 Portable
Hi,
Any progress on a portable eraserl.exe?
Regards,
niche99
Regards,
niche99
- niche99
There aren't issue with this, right?
Hi,
I don't have issues with it. But I assume you are asking the other admins/developers?
Regards,
niche99
Regards,
niche99
- niche99
Well there aren't anything that has come to my attention that needs urgent fixing so this beta can be used for everyday purposes if you so choose. But it is a beta still.
Hi,
The link posted only contains eraser.dll and eraser.exe.
Are you planning to release a portable eraserl.exe (ie the command line version)?
Regards,
niche99
Regards,
niche99
- niche99
Return to Eraser Update Alerts
Who is online
