Eraser 5.8.7-beta 3 Standard and Portable
• Page 1 of 1
Hello all,
I've spent a bit of time recently working on Eraser v5 and I'm glad to announce the release of Eraser 5.8.7-beta 3. This release contains about a dozen fixes and includes both the standard installed version as well as the portable version.
The Installer (unified for x86 and x64): http://www.heidi.ie/download/Eraser%205.8.7-beta3_setup.exe
Portable Zip (only x86): http://www.heidi.ie/download/Eraser%205.8.7-beta3_portable.zip
Changelog
Do post bugs for both releases on Trac. A stable 5.8.7 will be targeted for Sunday.
Regards,
- MD5: 6059aa0f768672695a28a3c9735d0d3c
- SHA-1: 0a6a757e39941b09a6e839278539a800d5e48e00
- SHA-256: 0843596c7bae8ac064e2d48b83a438be2c4b6749a7dd63839f058fa72f470427
- Whirlpool: 93b703b6ba80715bed8a7136a86db163397014ce506e1e02fad950962bb78b05cc5d9613499448c0a99573164962b94c1e812ef2fa9b6dc87ee4e5b282e3116c
- MD5: 7dbd4f3c423bc0b9cbc7ebe924d2f5ee
- SHA-1: 7921ed5f29ccc57290bc91093c04db62d694d1b9
- SHA-256: c12975c26f32dc9fadb8421d77337a2c676577ac69502d4d2def2bdb59e20873
- Whirlpool: b1d56edc0e93d4de4a6b7f7d4802ae1240184814353928b8ec76e52f9f83bcd8e5bc14b9173c136883fe5f227b94b33bdfe67d628d1d95b92879cbfd07972be
Changelog
- Fixed command line error when selecting subfolders to be erased with the parent folder
- Fixed a few issues with EraserL creating a registry key after an erase
- Fixed the weird bug of right-clicking the various erase methods and Eraser hangs. Hopefully this resolves the problem of the file/folder selection dialog blinking and resetting the selections.
- Implemented NTFS EFS file erasure (EXPERIMENTAL!)
- Further complicate forensics: Set MACE to invalid values (NTFS only)
- Fixed #6: Incorrect 'When Finished' option
- Implemented #37: Eraser should not allow system to hibernate or standby when running
- Fixed #36: Eraser overriding Windows hotkeys in context menu
- Fixed #48: Inaccurate determination of process elevation
- Do not create "New Eraser Document" in the New context menu of Explorer when using a Portable version
Regards,
Joel - Eraser DevTeam
Re: Eraser 5.8.7-beta 3 Standard and Portable
Downloaded and installed the portable version of Beta 3 and so far, she's LOOKIN' GOOD ! Just crossing my fingers that you will be able to nail that bug that prohibits erasing URLs. THANKS, Joel ! ! ! !
- gbjennings
OOOOOPS.... I wrote too soon. One major problem in beta 3, at least to me - I installed it and soon learned that there is no way to change the number of overwrites, either via the context menu or erasing the recycle bin. The default seems to be '35', and I have been totally unsuccessful finding a way to change this. I personally erase huge (multi-gigabyte) system backups and I'm not about to wait for a utility to overwrite that 35 times.
Please educate me if there is a quick hack to change the default for this setting, or please consider giving the user the ability to change the default. Thanks for listening, Joel.
Please educate me if there is a quick hack to change the default for this setting, or please consider giving the user the ability to change the default. Thanks for listening, Joel.- gbjennings
After right clicking the file and selecting Erase, there's a confirmation dialog. At the bottom left there's an Options button. Select that and select the number of passes etc. Accept changes on the dialog and select yes to the confirmation dialog.
Regards,
Regards,
AH, YES ! Thanks, Joel ! My 'auto button pusher' (RtvReco) was flashing past this screen so fast I did not see the options button. All seems to be working now. Thanks again ! !
- gbjennings
Hello, "Eraser 5.8.7-beta 3 Portable" still creates "Eraser.INI" in root of Windows system folder (C:\Windows\ for me) and it recreate it after i delete it (all like in beta 1).
OS - Microsoft Windows 2003 R2 (version: 5.2.3790 Service Pack 2)
Content of it different from file in eraser program folder:
Also i have small feature request, is it possible to add "Pause" button, not only "Stop"?
P.S. Wrong URL to Standard version, correct one - http://www.heidi.ie/download/Eraser%205 ... _setup.exe (space missing).
[5.8]
Library=BIBIPPBAAABAAAAA
- JB
Oooh new version number standard
- jackjack
I'm not trying to complain but it has been over three weeks since
was posted. That makes me think that there are serious issues with this version, and why the final hasn't been released. Is this version okay to use?A stable 5.8.7 will be targeted for Sunday
- n8chavez
creates c:\windows\Eraser.INI for me.
Content of file:
[5.8]
Library=BIIIPPBAAABAAAAA
Content of file:
[5.8]
- Crumbles
n8chavez wrote:I'm not trying to complain but it has been over three weeks sincewas posted. That makes me think that there are serious issues with this version, and why the final hasn't been released. Is this version okay to use?A stable 5.8.7 will be targeted for Sunday
Yes it is perfectly fine. I can't release any official versions (official software is released under Garrett's company) and I've informed Garrett that 5.8.7 is ready for release... but it seems like he's been too busy lately...
Joel,
Any word with the creation of the Eraser.INI in root of Windows system folder C:\Windows ??
- Crumbles
A few questions:
- How do you start Eraser?
- Is it through a shortcut, if so, what is the shortcut's Working Directory?
- What do you do when Eraser starts
- Is the INI file appearing immediately after the program starts or do you only find it after the program exits?
Never mind, I'm an idiot. I just did a bunch of testing and I cannot get the file to show up now. I guess the .ini file was from an old build or something.
Sorry.
Sorry.
- Crumbles
• Page 1 of 1
Return to Eraser Update Alerts
Who is online
Users browsing this forum: Google Feedfetcher and 1 guest
