Can't erase network files
Postby cruise2001 » Thu Jul 02, 2009 9:55 pm
Hello.
I am a long time user of eraser...but since I installed a Windows LAN in my home, it hasn't worked.
Any UNC path ( \\Computer\Share ) won't erase.
I have tried bother the portable and regular versions and am hitting my head against the wall.
I read the description on the homepage:
"Erases Network Files, Floppy Disks, CD-RW, DVD-RAM, DVD-RW."
...but no joy.
Help Please.
cruise2001
Re: Can't erase network files
Postby Joel » Fri Jul 03, 2009 12:14 am
Which version are you using and how are you erasing the files? Please detail your steps.
User avatar
Eraser DevTeam
Postby cruise2001 » Sun Jul 05, 2009 4:24 am
I am using 5.8.7.
I try to erase using "right click" or opening the on demand screen, dragging and dropping.
I hit erase and the files goes nowhere. I have a empty error report after it runs.
cruise2001
Postby Joel » Sun Jul 05, 2009 5:57 am
Did you refresh the explorer view? Are you able to delete the files normally?
User avatar
Eraser DevTeam
Postby cruise2001 » Mon Jul 06, 2009 1:41 am
If you are asking did I refresh the view to confirm the file still exists...yes.
And yes, eraser works fine on all other local files.
cruise2001
Postby Joel » Mon Jul 06, 2009 1:48 am
No, I meant if you have tried deleting the network file normally, not using Eraser.
User avatar
Eraser DevTeam
Postby cruise2001 » Mon Jul 06, 2009 12:53 pm
Yes, I can delete the file normally.
cruise2001
Postby snowdrift » Tue Jul 07, 2009 6:19 pm
I have noticed the same problem. If you map your volumes, it will work (it does for me).
snowdrift
Postby cruise2001 » Tue Jul 07, 2009 7:15 pm
snowdrift wrote:I have noticed the same problem. If you map your volumes, it will work (it does for me).
Thanks...I am using a networked Windows Domain environment with folder redirection. The desktop and many common directories are actually stored on the server. So any general erasing is really a UNC path (\\Server\SHARE).
This makes things difficult.
It may be better and solve many problems by simply saving files to a local disk in the workstation and deleting from there. Thanks...
Stay safe and Secure.
cruise2001
Postby Joel » Tue Jul 07, 2009 10:58 pm
Ah, okay. I have the same setup where I am but I don't think I've run into any problems I'll file a ticket to see that I do test that scenario, thanks!
User avatar
Eraser DevTeam
Postby Joel » Wed Oct 28, 2009 8:14 am
Fixed in SVN trunk.
User avatar
Eraser DevTeam
Return to Eraser Support
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
