Erasr 6 : Adding a Pseudorandom Erasure Task
Postby Gary2009 » Fri May 25, 2012 8:10 am
Hi ,
I am a Application Packager and i have a requirement to add task to erase "Temporary Internet Files", and the task should run in every user profiles after the application is installed.I have manage to add task by command "addtask -m=bf8ba267-231a-4085-9bf9-204de65a6641 -q -s=restart -d=" %userprofiles%\AppData\Local\Microsoft\Windows\Temporary Internet Files" via vbscript but the Erasure method is set to default. kindly let me know how can i set it to “Pseudorandom Data (1pass)”
Please help me with the above issue.
Thanks & Regards,
Gary
Gary2009
Re: Erasr 6 : Adding a Pseudorandom Erasure Task
Postby Joel » Sun May 27, 2012 11:19 pm
Good catch. The command line does not respect the method GUID when specified on the command line. I've opened Trac Ticket #443.
User avatar
Eraser DevTeam
Postby Gary2009 » Fri Jun 01, 2012 5:56 am
Thanks for your support .
So now is it possible to set the erasure task to "“Pseudorandom Data (1pass)” through a command line or i'll have to wait till the Trac Ticket #443. is resolved :)
Gary2009
Postby Joel » Sat Jun 02, 2012 6:37 am
I'd fix it in the coming days; if the fix is urgent you can try a nightly build on our downloads page (I'll state the build to use in the ticket when it's fixed)
Regular nightly build warnings apply.
User avatar
Eraser DevTeam
Postby Joel » Tue Jul 03, 2012 5:42 am
Strange, I'm running build 6.0.10.2731 (see our nightly builds) and I can't reproduce the problem now... can you check if it's solved?
User avatar
Eraser DevTeam
Postby Gary2009 » Wed Oct 17, 2012 6:53 am
Hi Team,
We can now set “Pseudorandom Data (1pass)” method via command line. Thanks for the support.
We have a further requiremnt of setting the same task to run on every restart.can this be possible via command line?
Regards,
Gary
Gary2009
Postby Joel » Tue May 07, 2013 12:22 pm
Ah, that's a problem. The run-on-restart tasks now only work for one-time restart tasks.
You might be able to get away with creating a new task via command line and task scheduler.
User avatar
Eraser DevTeam
Return to Eraser Support
Who is online
Users browsing this forum: Google [Bot] and 3 guests
