Manual Update Using Check for Updates
Postby shinerweb » Thu May 31, 2012 11:31 am
Hi,
After a quick search of the forum I can't find anything similar to this so am asking out of interest...
I've only juts found Eraser and am extremely happy with what appears to be a great tool.
This morning however, out of interest I clicked the "Check for Updates" and there was a new build of 6.0.10.2620 (Current build 22 May 2012 08:12:21)
The new file downloaded, but upon completion, it failed to open and instead brought up the file association window but with no options to 'execute' the downloaded file. The only option available is to close the update panel.
This doesn't even result in an error.
The file attempting to be downloaded was called "download-1" with no file extension.
Not sure what system call Eraser is using to launch that file, but I suspect it's not the regular "launchexe" call.
It's almost as if it's using a browser open function call.
I'm running on Windows 64bit, fully patched, all .Net's current etc etc.
I'd have expected more reports of this error given the number of users, so it might suggest some weird setting specific to my build. I just can't place which... (file association would be one area, but given no extension, I can't see that working on most systems).
Other than that, great product...
Regards
Chris
shinerweb
Re: Manual Update Using Check for Updates
Postby Joel » Sat Jun 02, 2012 7:06 am
I thought I fixed this a few versions ago. What version do you have currently?
User avatar
Eraser DevTeam
Postby jimmyg » Sat Jun 02, 2012 9:05 pm
I also experience the same thing as the OP with Eraser 6.0.10.2620.
Incidentally, why is Eraser saying there is an update (6.0.10.2620) available via "Check for Updates" when "About Eraser" says 6.0.10.2620 is already installed? I did notice that the core plugin is version 6.0.9.2620, not 6.0.10.2620.
jimmyg
Postby Joel » Sun Jun 03, 2012 7:03 am
Ah, I see why now: the code is indeed reporting 6.0.9 to the server. I'll fix the code but I don't think at this point it is worth the effort pulling the version from SourceForge, building another version and re-releasing another 6.0.10.
Please comment if you think the version should be withdrawn, and include reasons please (so far this is the most major issue, and it does seem to be cosmetic in nature)
User avatar
Eraser DevTeam
Postby Joel » Sun Jun 03, 2012 7:08 am
Version checking fixed in r2719.
User avatar
Eraser DevTeam
Return to Eraser Support
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
