Overwriting once is enough
• Page 1 of 1
http://www.heise.de/security/Sicheres-L ... ung/121855 (in German)
http://www.heise-online.co.uk/news/Secu ... t--/112432 (in English)
http://www.springerlink.com/content/408263ql11460147/ (Paper in English)
They concluded that, after a single overwrite of the data on a drive, whether it be an old 1-gigabyte disk or a current model (at the time of the study), the likelihood of still being able to reconstruct anything is practically zero. Well, OK, not quite: a single bit whose precise location is known can in fact be correctly reconstructed with 56 per cent probability (in one of the quoted examples). To recover a byte, however, correct head positioning would have to be precisely repeated eight times, and the probability of that is only 0.97 per cent. Recovering anything beyond a single byte is even less likely.
Often we hear controversial opinions in digital forensics on the required or desired number of passes to utilize for properly overwriting, sometimes referred to as wiping or erasing, a modern hard drive. The controversy has caused much misconception, with persons commonly quoting that data can be recovered if it has only been overwritten once or twice. Moreover, referencing that it actually takes up to ten, and even as many as 35 (referred to as the Gutmann scheme because of the 1996 Secure Deletion of Data from Magnetic and Solid-State Memory published paper by Peter Gutmann) passes to securely overwrite the previous data. One of the chief controversies is that if a head positioning system is not exact enough, new data written to a drive may not be written back to the precise location of the original data. We demonstrate that the controversy surrounding this topic is unfounded.
- Walda
Re: Overwriting once is enough
Thanks for the post!
Joel - Eraser DevTeam
This is good info.
It's easy to delve headfirst into a hard disk wearing 35 pass overwrite hoping you are now completely secure.
Always suspected that a proper overwrite didn't require more than a few passes, it surprises me none the less that a single pass is enough.
Cheers
Cheers
- Snoogins
Good article. I knew this But technically one overwrite in software is (either) not good enough (or unnecessary if you use the right hard drive ... further follows)!
An ATA Secure Erase should performed which erases those mapped out dud and flakey sectors dynamically mapped out by the HDD controller that might just accidentally have had your banking etc PIN on it that you typed into a txt file and forgot lest you would forget your PIN too and could get mapped back in again if they turn good or under appropriate instructions to the controller...
If you use a FDE (Full Drive Encryption drive using AES (like those from Seagate and my next and permanent future upgrades) then provided your password is complex enough they shouldn't be readily cracked and the contents of your should appear necessarily - for the encryption to be any good - pseudo-random -: you therefore never need ever erase the drive before re-purposing it -: just reset your password to nothing and the drive may then be re-used by and all and sundry and nothing to worry about...
Message me and I will provide links to info if anyone really doesn't believe or cannot find more the info for themselves...
So you can see why my next drive(s) will be FDE that work transparently with the BIOS HDD Power-On Password support (that I already use anyway even though it is crackable by experts with a regular non-FDE drive).
Cheers and thanks for the articles anyway although I personally don't need em.
(Mind you I am thorough little bugger so I will come back and skim em - thanks...)
Regards all...
matthew
Regards all...
matthew
- matthewsheeran
Old habits die hard though so I reckon I would do either an ATA Secure (H/W) Erase first or a single pass of pseudo-random bytes (S/W Erase) so the non-zero mapped out sectors that might get or be mappable back in again don't stick out like dogs balls amongst alternatively zero-ed sectors even on an FDE drive! Mind you, zero writes to the sectors in the latter case wont be zero's if this is done while any password is still set on an FDE drive, although, if done while the password (and therefore) encryption is off (i.e. may be blank password etc depending upon the exact mechanism) there will be so little mapped out and hidden area data left over to process for decrypt-analysis purposes that perhaps cracking even a lousy password might be a very low risk and difficult scenario indeed when the bulk of the data you want to process has already been zero-ed out!
Finished finally,
Matthew
Finished finally,
Matthew
- matthewsheeran
Agreed, and that is a very real problem when erasing under User mode (and even DBAN too) but most modern drives have a relatively low remap count, and if you are using those spare sectors then you probably should be getting a new drive (and mechanically destroy the old drive.) Sectors almost never become "good" from "bad" as far as I know.matthewsheeran wrote:An ATA Secure Erase should performed which erases those mapped out dud and flakey sectors dynamically mapped out by the HDD controller that might just accidentally have had your banking etc PIN on it that you typed into a txt file and forgot lest you would forget your PIN too and could get mapped back in again if they turn good or under appropriate instructions to the controller...
There's always the possibility of a key compromise, and the remote possibility that AES is broken tomorrow -- go figurematthewsheeran wrote:If you use a FDE (Full Drive Encryption drive using AES (like those from Seagate and my next and permanent future upgrades) then provided your password is complex enough they shouldn't be readily cracked and the contents of your should appear necessarily - for the encryption to be any good - pseudo-random -: you therefore never need ever erase the drive before re-purposing it -: just reset your password to nothing and the drive may then be re-used by and all and sundry and nothing to worry about...
That also applies to regular user-level erasures -- if only a minute amount of data remains, then it is highly unlikely that it would b recoverable.matthewsheeran wrote:if done while the password (and therefore) encryption is off (i.e. may be blank password etc depending upon the exact mechanism) there will be so little mapped out and hidden area data left over to process for decrypt-analysis purposes that perhaps cracking even a lousy password might be a very low risk and difficult scenario indeed when the bulk of the data you want to process has already been zero-ed out!
• Page 1 of 1
Who is online
