DBAN 'load averages' question
How do I completely erase my PC?
Moderators: dajhorn, Eraser DevTeam, Eraser Moderators
Postby tom_petty » Mon May 09, 2005 8:10 pm
What do the 'load averages' values mean :?:
tom_petty
Postby dajhorn » Mon May 09, 2005 11:01 pm
The unix "load average" is a measurement of system activity.
An idle computer has a load average of 0. A process that can use all CPU time adds 1 point to the load average. A process that is waiting for I/O to happen also adds 1 point to the load average.
You can think of a load average between 0..1 as a percentage of system utilization. For example, a load average of 0.25 means that the system is 25% busy. Load averages greater than 1 indicate resource overcommitment. For example, a load average of 2 means that the computer would need to be twice as fast to handle the entire process schedule.
Postby tom_petty » Tue May 10, 2005 5:24 pm
OK, thanks...
...but there are three values, usually different.
Do they have special meaning ???
tom_petty
Postby dajhorn » Tue May 10, 2005 8:52 pm
The numbers that you see in DBAN are for three rolling intervals: one minute, ten five minutes, and fifteen minutes. These are the same numbers that you would get from the `top` or `uptime` programs.
Return to DBAN (Dariks Boot and Nuke) Support
Who is online
Users browsing this forum: No registered users and 2 guests
cron
