I have 2 questions. One is about index.dat and the other is about the paging or swap file.
1) I want to erase index.dat. In the FAQ section at the Eraser website it says the following: "Index.dat can only be erased on Reboot. Create a new task and schedule it for Reboot."
I know how to create a New Task. I also know where to find index.dat. What I do NOT know is how to schedule a new task for Reboot. How do I schedule a task for reboot? I don't see a box to check or any option that specifically mentions Reboot.
2) I recently erased all of the unused space on my hard drive. This is the first time since changing my operating system from Windows 98 to XP that I've used Eraser to wipe all of the free space. Before I erased the free space I disabled the paging file just like I used to do with Windows 98. After Eraser had finished 5 hours later I went back to enable the paging file and discovered that I didn't have to. Apparently XP had overridden the change I had made. Has anyone else had this experience?
I've read through the literature at the Eraser website and if I understand it correctly I no longer have to disable the paging file prior to erasing the free space. I should instead check the "Enable clearing of paging file (swap) at shutdown" box, correct?
