A Trusted Way to Convert OST to PST
alex786
In the workplace, Microsoft Outlook is a popular email client.
When the user creates their Outlook profile and configures with the MS Exchange Server then the Offline Storage Table (.ost) file format gets formed. These file allows user to check the content in it in the Offline mode. However, for many reasons, users look to convert OST to PST files, and if you are one of those, this write-up is useful for you.
Reasons for OST to PST Conversion
A user may need to convert a .ost to.pst for a variety of reasons, which are described below.
  • MS Exchange servers can go down for a variety of causes, including but not limited to Malicious Software Virus Attacks, Power Failure, etc.
  • Error messages show up over and over again in these kinds of situations, making it tough to manage them.
  • Sometimes it's challenging to get mailbox data because the Exchange Server is being maintained or unavailable. If the .ost extension is used to save data in the mailbox. It will be permanently locked out of the mailbox. Exporting emails from OST to PST is the only way to gain access to the data.
  • Corruption and unintentional removal are no challenges for OST to PST data recovery.
After discussing common reasons behind the OST to PST conversion, let’s check out some methods that help convert OST to PST files. In this write-up, we will focus only on professional software because manual solutions are harder to use for non-technocrats. Additionally, any single mistake by the user during the manual process can put the data at risk.
Professional Software for Converting OST files into PST
There is several software which guarantee to offer safe data conversion, but only some of them deliver the desired outcome. There is one such solution which is Shoviv OST to PST converter, which perfectly executes the conversion task in a quick time frame. It allows users to convert OST to PST which any difficulties due to its better user interface. Users can add multiple large-size OST files without the size constraint.
The software allows previewing of the OST file's content before converting them into PST file format. It even allows repairing severely corrupted OST files. Along with PST file format, the software also enables users to save the OST file item into formats like MSG, EML, HTML, etc. The tool comes with the free demo edition, which allows users to process the first 50 items from each folder.
Conclusion
Despite their benefits, manual procedures have several drawbacks, including the fact that they can be time-consuming. If you have MS Outlook with Exchange Server, you can manually convert OST to PST for free. These methods generally require more time. One of the most efficient and convenient methods is to use third-party software. It is highly recommended that you utilize this software due to its ease of use and robust features.
Get More Info: OST to PST Converter
If you want to finish the OST data recovery and conversion in just a few minutes then you should use SysOZ OST to PST Converter. This tool is also very easy to use and also work very fast. With the help of this tool you can also see the preview of the conversion and can also convert the large sized PST files into small bits as per your needs. You can convert your data into various formats like PST, EML, MSG, vCal, and vCard etc.
