Gorgeperker
If your folders contain many duplicate MBOX files after multiple exports, the most efficient way to clean them is by using a dedicated tool like TrustVare MBOX Duplicate Remover. The software scans all MBOX files, compares key attributes such as subject, sender, recipient, and date, finds duplicates, and quickly removes them without any problems. It safely eliminates only the MBOX duplicate entries while keeping your original emails saved. The tool is user-friendly for non-technical users, and they can use a free trial without any technical skills. It will work on all Windows versions 11, 10, 8.1, 8, and 7. It doesn’t require any software installation on the PC, and a free trial is available to use this software before purchase. Using this tool helps you organize your MBOX files, free up storage space, and maintain a clean email archive.
