After using Eraser my Hard Drive has no memory left
matthewandruth
Hello. After using Eraser my Hard Drive has no memory left. I thought maybe using CCleaner would delete all files but that didn't restore my hard drive space. Now I'm not sure what to do, short of erasing the entire partition and starting from scratch. Any ideas why this happened after using Eraser and what I can do to restore my hard drive space? Thanks a lot!
Go look for a folder in the root of your hard drive: It's got garbage as its name and contains hundreds of other files with garbage as its filename. Delete that folder. Alternatively, you can go look at the task log (right-click on the task > View Task Log) and extract the path to the folder there.
