Users are looking for ways to convert Excel file contacts to vCard format, but they are unable to do so due to a lack of suitable solutions. We'll go through a smart solution for exporting Excel contacts to vCard format in a few easy steps in this article.
How to convert XLSX contacts to vCards –
1. Run the XSL to VCF Converter Tool after installing it.
2. Select an Excel file using the Browse button.
3. This will show all of the contacts in the Excel file. You can map Excel columns to vCard fields in this section. Press the Export button now.
4. Select the Browse button and enter the place where you want to save the VCF file. You can choose to “Export all Excel contacts into a single vCard file” from this menu.
5. Click the Export vCard Now button to convert all of the contacts in the Excel file to vCard format.
Read More: SYSessential Excel to VCF Converter
