Manoj Sharma
If you're encountering the "Encrypted Connection is Not Available" error in Outlook, it typically means that Outlook is unable to establish a secure (SSL/TLS) connection with your email server. This may happen due to incorrect port numbers, unsupported encryption methods by the server, expired or invalid SSL certificates, or a misconfigured Outlook profile. Manually resolving this involves checking and correcting your account settings: go to File > Account Settings > Account Settings, then double-click your email account and click More Settings. Under the Advanced tab, verify the correct port numbers (usually 993 for IMAP with SSL and 465 or 587 for SMTP with TLS) and ensure encryption types are properly selected. Also, ensure your antivirus or firewall isn’t blocking Outlook’s connection. However, these steps can be time-consuming and technically challenging for non-technical users.
A much easier and efficient approach is using the Cigati Outlook PST Repair Tool. This advanced tool not only repairs corrupted PST files that may be causing the issue but also allows you to recover mailbox data and reconfigure it with correct settings. It supports encrypted PST files and helps restore secure access without requiring complex manual setup, making it ideal for both professionals and beginners facing Outlook connection issues.
