Automated PST splitter vs manual export – which is safer?
When it comes to splitting large PST files on Mac, people frequently choose between manually exporting and utilizing an automatic PST splitter such as Mailvita Split PST for Mac. Both systems have advantages and disadvantages & but safety and efficiency are primary factors.
Manual export
This method involves exporting mailbox folders manually from Outlook to create smaller PST files. While it is free and does not require any additional software and it is time consuming and prone to errors. Large PST files can get corrupted during manual export especially if the operation is paused. Furthermore you must carefully choose folders and verify that none are skipped, which increases the risk of unplanned information loss.
Automated PST Splitter
Mailvita is a tool that is specifically developed to safely partition large PST files without any data loss. They allow for dividing by size, date or folder and resulting in a more ordered and consistent outcome and the automated approach reduces human error & allows for bulk processing and ensures email integrity, attachments and folder structure.
Conclusion For customers that value safety, speed and accuracy, an automated PST splitter is significantly preferable. Manual export can be used for tiny PST but for large or critical mailboxes and expert applications such as Mailvita Split PST for Mac are a better option.
